Results 1 to 9 of 9
Thread: Vh
    Vh sle 5ltr 83
    Mar 2008
    Default Vh
    hello i was just wondering what type of auto transmission does the vh commodore 308 sle come out with and whats a good replacement for performance but getting some better economics also im getting it put on gas soon with the fuel hitting 170 and having a holley also what would be some good not overly priced to give it some more spring in it's step im a p plater so moneys a big factor
    thanks
    also i was wondering my heater doesn't get much warmer when i switch it to heat maybe 1c warmer what would be my most likely problem with this maybe my thermo stat opening early or something my heat stays in the blue line pretty the whole time in less it's summer and goes level with the end of the blue line
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    trimatic is the auto in the VH SLEs.
    The heater, perhaps the air con needs a rebuild? Thats what they have.
    Vh sle 5ltr 83
    Mar 2008
    im talking about the heater not getting warmer i have talking the belt off the aircon not know whats wrong with it
    Vh sle 5ltr 83
    Mar 2008
    oh and also i took my car for a spin checked my top radiator hose and it wasn't hard what does that mean
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Quote Originally Posted by benny999 View Post
    That is the problem. The heater works off the air con.
    The top radiator hose not hard after a drive is normal. If it was hard, that means the thermostat is stuffed.
    Vh sle 5ltr 83
    Mar 2008
    Default aircon
    ok so if i put the belt on it should work also does it need to be connected to the power because i think the wires on the aircon because its not connected and theres only one wire coming off the aircon and it's a thin black wire we a little round connector on the end should there be more
    Vh sle 5ltr 83
    Mar 2008
    i was wondering if any one had the wiring diagram for the vh sle aircon also i found this on vicroads you might wanna notify them of this change
    Change of gender : VicRoads
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    I have a wiring diagram for a VK probly.... and haha nice link, just sent that to my mate.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Vh sle 5ltr 83
    Mar 2008
    ok cool you reackon you could post it or something or is there a way to bypass my problem?
    thanks
