Results 1 to 7 of 7
Thread: upgrading vk brakes
    VK 3.0
    Jul 2008
    Default upgrading vk brakes
    hey guys just asking is it possible to upgrade the vk brakes to maybe vn or some think im running an rb30 soon to be turbo'd and very keen on new brakes
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Why not just by a VL?
    Dont see why you would want to molest a VK to put a crappy nissan engine in, but each to their own.
    Not sure on VN brakes, id say its a possibility as they both run the same front K-Frame (early model VN's) and use same rotors etc. Or look into the VT twin piston conversion.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VK 3.0
    Jul 2008
    thanks for the reply i got the car as it is now i didnt do the rb30 conversion and hey it works it goes and pretty hard i may say so you reckon early vn's maybe vt twin pot thanks once again
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by mantisvk View Post
    Someone else will be able to share more on the matter, but id say VN brakes are possible with out to much stuffing around.
    Otherwise VT twin piston brakes would be the go, you can get a front set off ebay for around 500.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by Tom_1569 View Post
    Because vl's are ugly and rb30 is a better motor than a 202 but anyways you're best bet are as tom said, Look for v8 front brakes or vp s2 use the same front brakes these have a larger disc and a finned front caliper. Thats the cheapest option for the front and bolt straight up. VT is the best option but require special hubs for earlier models. Cost would be around 3 or 4 times the price of v8 upgrade. Rear if your running drum brakes is go for a whole new diff with disc brakes. Mainly vk and vl (calais mainly) are your best best as vn are slightly wider and not ideal for the vk. You can convert drum to disc but there's a bit of work and it might be easier changing the whole diff.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    VN v8 brakes are the same size as vl vk v8 and vl turbo. so either find a smashed vl/vk v8 or a vl turbo. the front disc is slightly larger (1 inch?) and have fins on the front caliper
    ========My Statesman 20's Mafless and 3.9's========
    VK Calais 3.8L
    Jul 2008
    Queensland
    VN and VK diff's are not the same.
  1. Upgrading Brakes
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2007, 04:00 PM
  2. Upgrading Disc Brakes
    By vn88calais in forum General
    Last Post: 22-06-2006, 08:11 PM
  3. Upgrading a VS 3.8 to VS 5.L
    By NeilB in forum V8 Development and Modification
    Last Post: 31-01-2006, 12:16 AM
  4. vt upgrading
    By phoenix_984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2005, 08:30 PM
