Results 1 to 24 of 24
Thread: Decode vin any one?
    Jul 2008
    Default Decode vin any one?
    Hi Folks,
    would like to decode my chassis number 8K69NK706711C
    any advise appre ciated,
    cheers
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I'll have a go...
    8 = Holden
    K = Exec
    69 = Sedan
    N = Engine?
    K = 1980 production
    706711 = S/N
    C = VC
    and 3 Dangerous non ABS VN's
    Jul 2008
    Jul 2008
    Also this car has a fuel filler on both sides of the car factory any one else with that ! with 253 manual,
    was wondering it it a special model?
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by freeoate View Post
    Dont know if it's factory for 2 fillers - But a mate of mine put a second long range tank into a HZ wagon.
    The engine code I'll lookup. Back soon......'click' (door closes)
    88GreenVN's Avatar
    Jun 2006
    The engine option code is L36 for the l/comp 4.2L
    On the body plate the letter following the Body Number is the place it was built
    A = Adeliade
    B = Briz
    M = Melb
    S = Syd
    NZ = NZ
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Theirs another tag telling you the engine trans and diff + paint, model, body number, trim and buld date.
    8 = Holden
    K = Commodore SL
    69 = Sedan (only by 88greenVN) said
    N = Cant find an engine N anywhere
    K = 1980 Model
    SHOULD BE ONE MORE LETTER Followed by 7 for the plant
    06711 = S/N
    C = VC
    Twin fuel fillers has me stumper unless it has either a sub tank or a long rang tank, but still cant see the need for two fillers.
    Last edited by Tom_1569; 19-07-2008 at 05:54 PM. Reason: add what the missing letter is for.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Tom_1569 View Post
    8 = Holden
    K = Commodore SL
    K = 1980 Model
    06711 = S/N
    C = VC
    The K was for the Commodore. The SL was the Berlina of today "L".
    Jul 2008
    I cany find any other tag, and the only tag has 8k 69 nk -06711.
    it is New Zealand New, assembelled i dont know, the lefthand fuel filler cap is a dummy so to speck but it is factory, got me stumpped too
    88GreenVN's Avatar
    Jun 2006
    New Zealand
    Other tags will be on the front cowling beside the radiator. Some times a body number can be found under the left headlight.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by 88GreenVN View Post
    Ummm *bites tongue and thinks* this may be different for the VC's but a VK SL is the base model and K stood for it, must of been a change somewhere along the lines. Did VC's also not have the plant in the plate?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    I'm not arguing here, but what makes you think the left hand filler is factory? It may have the factory filler door, on the left hand side.
    Also, K is the base model, since this is a VC, its the L base model. If it had 8L69, SL spec.
    Jul 2008
    88GreenVN's Avatar
    Jun 2006
    VB VC cars had K L X for the 3 models.
    plants
    H1 - H4 Bris
    H5 - H9 Syd
    J1 - J9 Mel
    L1 - L9 Adel
  15. #15
    88GreenVN's Avatar
    Jun 2006
    hers a pic or two of the filler
    Is it for a gas converted car?
  16. #16
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Hmmm, i'm really thinking that, perhaps the rear quarter has been replaced, with an imported panel, say from Opel.
  17. #17
    Jul 2008
    its never been on gas, its identical to the orig rh side one from the outside,
    but you could be on to something there,
  18. #18
    Jul 2008
    Quote Originally Posted by SL/ENUT View Post
    another good idea,! so they came out left hand drive as well?
  19. #19
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    And the VH and VKs too.
    K denotes base model, VB, VC's L, VH's SL, VK's Exec and SL
    L denotes SL in VB-VC's, VH's SL/X and VK Berlina's
    X denotes VB-VH SL/E, Calais in the Vks
  20. #20
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    the Holden Commodore, VB, really started out as a modified Opel Rekord/Opel Senator. German made, they are left hand drive.
  21. #21
    Jul 2008
    well amazing, i looked at a few lefthand drive opels and filler cap on RH side, same as commodore, mystry!
    Attached Thumbnails Attached Thumbnails Decode vin any one?-opel_rekord-e-77-1977-1982_r4.jpg   Decode vin any one?-vc-003.jpg
  22. #22
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Well, its a mystery for me too.
  23. #23
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I have a feeling its an export model for a LHD country, would holden be this bodgy? its maybe either that or someone did it custom themself for a gas setup that never happened.
    Attached Thumbnails Attached Thumbnails Decode vin any one?-holden_export_35.jpg   Decode vin any one?-holden_export_36.jpg   Decode vin any one?-holden_export_37.jpg   Decode vin any one?-holden_export_38.jpg
    ========My Statesman 20's Mafless and 3.9's========
  24. #24
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by ucwepn View Post
    The HG's had a code for the export cars in the VIN.
    More looking tonight
  1. VIN Decode Please
    By Ute God in forum General
    Last Post: 10-02-2010, 10:22 PM
