hey people,
I have just put a new 308 in my Vh and the motor has low idle vacume but if i advance the distributer beyond spec the vacume comes up .I have put a new set of intake manifold gaskets through it and like to think i have eliminated that as a cause could it be that the cam timing is out a tooth on the timing chain as i didn't set the cam timing im thinking this could maybe be the cause. any info would be good thanks![]()
[SIGPIC][/SIGPIC]Those of you with V8 turbo & supercharged arse holes please use 1st or 2nd gear as this toilet is not fitted with MUDFLAPS.
The outer ring of the harmonic balancer might have slipped so the timing mark is not in the correct place. Try taking No1 spark plug out and winding over by hand to TDC then check the mark on the balancer
Yeah check TDC first. But sounds like cam timing may be out. Did you dial in the cam???
Just a thought.have ya got a wild grind on ya cam,m8 has a corvette with a mental cam and he has all sorts of trouble gettin his headlights to come up coz of low vacuum
Phillip![]()
hey people the problem was that the cam was out 6 teeth the guy that put the motor together F@#t up the cam timing so called mechanic, its all burnouts from now on
i had a mate that put me on to the vacuum Gage and thats how i found out it had late valve timing......... I would like to thank every one for there input its all been for a step in the right direction HOLDEN 4 LIFE
