| VB - VK Holden Commodore (1978 - 1985) Talk about anything relating to the VB-VK Holden Commodore. |
04-08-2008, 06:52 PM
Ride: VC SL/E 5.0L
I am so stumped, i have never had a challenge like thos
Ok, i found out that my motor has only been running on 5 pots instead of 8. Its pots 2,3 and 4. But heres the twist; the leads are sparking, a nice blue spark. Ive checked the dizzy cap and its all good. Ive checked the gap on the plugs which are fine. I even switched a firing plug with a non firing and there is no difference. DIJM8 thinks its the LPG system, which may be since its 2,3 and 4 in a row.
i have no idea how to solve this.
__________________
A butt load... one might ask just how much can you fit in a butt?
5.0 litres of nature burning fun!
04-08-2008, 07:24 PM
BURTON
Ride: VK SL
Leads/Plugs can spark fine when removed, but wont fire under compression (installed), but if swapping plugs and leads and it still happens on those cylinders then you can eliminate that.
Dizzy and Coil is a possibility, it may not be strong enough on those cylinders to spark under compression, but unlikely.
Do a compression test to make sure theirs not something wrong with those cylinders, could be stuffed rings, unlikely... more likely to be a cracked head gakset between those cylinders if compression is low.
Other wise yes it could be LPG not getting down their for some reason.... Sorry dont no **** about LPG.
04-08-2008, 07:48 PM
Ride: VC SL/E 5.0L
Ive got an oil pressure gauge and its getting great readings if that adds anything.
oh and also, when i was doing my exhaust manifold gasket, on the drivers side i undid a bolt to get the gasket out and all my coolant flowed out of it. It was only the one bolt that did it i believe but im sure its not normal...
__________________
04-08-2008, 07:56 PM
BURTON
Ride: VK SL
Quote:
Shouldn't really relate to your ignition problem, but good to double check you are getting oil pressure.
Have you got a compression tester?
04-08-2008, 07:58 PM
Ride: VC SL/E 5.0L
no but my dad does, what about that coolant problem when changing my exhaust gasket. Could that be a head gasket problem?
__________________
04-08-2008, 07:59 PM
BURTON
Ride: VK SL
Im not familiar with these motors, but Im pretty sure thats not normal lol.
04-08-2008, 08:02 PM
BURTON
Ride: VK SL
Grab the compression tester and do the test and post back.
Im not to sure on the coolant leaking out, ill leave it for someone else to answer.... But i dont think it should be happening, and it maybe a crack somewhere on the head, or could be the head gasket... A compression test would answer a bit, also you can get a mechanic to hook up a thing to the radiator and it will tell you if the head gasket is gone.
04-08-2008, 08:33 PM
lost in space
Ride: VXSIIV8berlina
check your firing order
1-2-7-8-4-5-6-3
__________________
Took
One
Young
Oriental
To
Assemble
04-08-2008, 09:30 PM
Ride: VC SL/E 5.0L
Quote:
1-2-7-8-4-5-6-3
did that, all in the right spots. I took the dizzy cap off as well and checked inside of that and all good.
__________________
04-08-2008, 10:14 PM
9-11-08 CRUISE FOR KEBAB
Ride: VE SV6, 52 Morris Coupe
How high is the oil pressure?
iv got another car running on 3 cylinders of the 4 as it needs a new piston ring. Not only does it run ****, but iv got blow by (check for smoke coming from the oil. Its exhaust smoke) and the oil pressure went from 40psi to 60psi when the ring broke.... its a possibility i guess
__________________
VE SV6 Manual
04-08-2008, 10:17 PM
Ride: V6 VP COMMODORE
what do you mean by 2 3 and 4 do you mean all on one side of the engine cause 2and 4 are on the same side but 3 is on the other side
04-08-2008, 10:29 PM
Donating Member
Ride: VN 90 5.0 wagon
is the manifold bolt on the same side as the cylinders that are not firing? (could be a cracked head)
__________________
Never late
In a fuel injected V8 Foamtuned
