Results 1 to 7 of 7
Thread: brock engine id
    5l vk calais
    Aug 2008
    Question brock engine id
    hey new to the site can anyone tell me the best way to tell if my vk calais has a brock engine in it
    vz wagon
    Aug 2006
    Wild west of Melb
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Look at the heads, could be "B" cast, the manifold numbers should end with 955 and also, whats the engine prefix?
    gruntavt's Avatar
    gruntavt is offline HSV-I Don't want one ;-)
    vess-luckily
    Sep 2005
    Quote Originally Posted by SL/ENUT View Post
    Nearly all correct, the heads could also have BS5/HDT stamped on them & the inlet manifold may be a modified stock one,with the 4 holes opened to two chamber size where the carby bolts up.
    Not another crap hsv
    82 VH 3.3L
    Jul 2008
    west NSW
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by axd52x View Post
    what about contacting HDT with the engine number?
    you could but your better of trying the Brock commodore Forums. someone there with a bible will know
    Body by Holden, Soul by Brock
    the Legend will live forever
    VK calais
    Jun 2009
    Exclamation vk brock or not
    Yep if you call HDT they will tell you if your car is or isn't a Brock.
    The VK's get mistaken for a Brock as, the real Brock motors are based on the vk motor. Engine numbers may be similar however the Brock motor has modified heads, different air intake, roller rockers and bigger compression ratios.
    I know this because i contacted HDT and found out as i have a vk calais and did some research to find out if it was a Brock. Searching on the net made be believe that is was a Brock motor as the numbers matched up, but it turns out all the vk numbers match up (LV2). This doesn't mean is a Brock motor though.
    You can usually tell if its not a Brockie if its stock and doesnt have kits on it.
    Hope this helps
  1. vl brock..
    By madvl8 in forum VL
    Last Post: 28-07-2008, 06:59 PM
  2. Bev Brock on ACA
    By Julie in forum The Pub
    Last Post: 10-09-2007, 07:06 PM
  3. 308 brock engine
    By gtr161s in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2007, 01:56 PM
  4. The Brock
    By perkins in forum VB - VC - VH - VK
    Last Post: 31-08-2006, 09:13 PM
  5. Looking for a VC HDT Brock or VK SS Brock
    By vc_brock_commodore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-06-2006, 12:10 PM
