Results 1 to 13 of 13
Thread: identifying vk diffs
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    Default identifying vk diffs
    I want to get a set of 4.11 gears for the diff in my vk wagon. how do i tell what diff it is and then what gears do i buy?
    gotta get a 17 somehow!!
    ECOTEC KICKED IN yO!!!!!!
    the lightning
    Jun 2005
    under the Southern Cross
    flange on diff with 4 bolts to tailshaft = borgwarner (is also cast into underside of the diff housing)
    small salisbury (octagonal rear plate with bolt) common in 202s, normal yoke that takes u-bolts
    big salisbury 10 bolt (almost tear shaped rear coverplate with bolt), normal yoke that takes u-bolts)
    getting 4.11s is easiest on a borgy diff as Fords used them too. dont bother rebuilding it unless its got 28spline axles.
    Quote Originally Posted by one_and_only2004 View Post
    Sounds like you and your friend have a collective intelligence rivalling that of a door knob. Looks like the useless crap you fit to your car is the driver.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    if it is a borgwarner diff then it will be a 2 spider center with 25 spline axles. this will fit 4.11 gears but the center isn't that strong really.
    Body by Holden, Soul by Brock
    the Legend will live forever
    May 2004
    darwin
    thanks for the replies. here is a picture. i'm still confused
    May 2004
    darwin
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    You've guessed right chief, that is a 8 bolt "small" Salisbury diff.
    May 2004
    darwin
    thanks!! so i suppose, the next question i should ask is, how hard is it to get 4.11s for it, and is it worth fitting them?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Don't think they made a 4.11:1 ratio for those, i know the bigger 10 bolt diffs had 4.44:1. I think its better finding the BW78 diff out of a VK and using that.
    May 2004
    darwin
    hrmmm, might have to wait.
    a mate has suggested getting a pintara diff. would that help?
    Huitzi is offline Huitzi
    1984 vk Calais
    Jul 2005
    You will need the vl diff housing and the pintara center, pintaras came with 3.9's and 4.11's 25 spline but skylines are 3.9 and 28 spline centers, + when you get the VL borgy diff don't forget to grab the tail shaft to go with it as your Salisbury one wont fit.
    I hope this is some help
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Quote Originally Posted by Huitzi View Post
    For a gear ratio change u don't use the centre, just the gears, the crown and pinion.
    Also, the VL tailshaft won't fit the Salisbury 8 bolt tailshaft (VL tailshaft is slightly larger in diameter). You need to get a tailshaft for a borg warner diff out of a VK. Harder to find, but it's the only option if u don't wanna spend a few extra dollars getting them customised. You need the front of ur current tailshaft to go into the trans, then use the rear section of a VK borg warner tailshaft to join up to ur borg warner diff.
    If u can find a R31 Silhouette, that not only has either 3.7(manual) or 3.9(auto) gears, but also LSD. The only thing is they are a 28 spline centre so you'd need to use different axles......but if u were gonna use the LSD centre out of a Skyline, u could just get a VL diff coz VL turbo's and 5.0L's use 28 spline axles......the VK borg warner diffs are 25 spline. VN (and upwards) axles are 28 spline, but those diffs are a little wider again so might need shortening or sumfin.
    Lots of mucking around.
    For my VK wags, I bought a Borg Warner diff (which was even harder finding a VK wagon borg warner diff), then got a 25 spline LSD off of ebay. I know 28 spline is the way to go, but I'm not making enormous amounts of power so I rekon it will be ok lol.
    1984 vk Calais
    Jul 2005
    Quote Originally Posted by DANNY8 View Post
    Very true you only need the crown and pinion gear but unless you are a diff specialist and are familiar with setting up clearances and back lash/crown to pinion wear i would use a complete mating center with its existing crown and pinion gears, its not an exercise for a novice setting up a borgy diff.
    DANNY8's Avatar
    Apr 2004
    Wouldn't ya have to get it adjusted anyways? Isn't it the shims either side of the centre which align it? And all shims are different aren't they? I'm not 100% sure, I'm leaving my diff to the professionals
  1. Help Identifying These Plugs :)
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-01-2008, 07:27 AM
  2. Identifying IRS?
    By Kstar. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 10:04 PM
  3. Help Identifying
    By spice_man2069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2007, 09:04 PM
  4. Identifying 3.8 V6 Origin...
    By Flamenco in forum V6 Development And Modification
    Last Post: 21-11-2005, 04:40 PM
