would someone be able to tell me how hard it is to replace the gasket for the master cylinder where it joins the brake booster and what i have to do to get the master cylinder off???
There's the bolt on the bracket holding the master cylinder to the strut tower, then u pull out the brake lines, disconnect the wire, and I rekon there's only 2 bolts holding it to the brake booster.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
thanks will hav a look at gettin it off later 2day
Yep they're the ones.
My mates whos a mechanic said not bother with a cheap set either. He suggested to me to get Kincrome as the least, knowing how rarely id use them, but was keen for me to get Snap-on. He said he doesnt care about other spanners, just these pipe spanners he recons you have to have the best..... Could just be a personel opinion though.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
yeah once we gott it apart we realised that there was no gasket or seal there so we gettin a new cylinder some one said to me it could also be the booster any ideas?
when i put my brake booster back into my car i was told to just put some grease into the hole that the master cylinder slides into. That worked for me but yea there is no gasket, there is a rubber gasket for the booster heading into the interior but other than that.
Yea if it is leaking then the master cylinder would be on its way out. I dont see how the booster could be the cause of the leaking since it just pushes the master cylinder and doesnt go inside the cylinder at all. If your booster was the problem your brakes would be rock hard, alot of hissing/ air rushing and hard to stop. I would know, i just fixed mine![]()
new master cylinder and you will be set m8. best of luck
Paiste402
thanxsfor that info Paiste402 got new master cylinder 2day will b putting it in 2moro arvo after work will let u kno if it solves the problem
budz
Paiste402 how much trouble did u have gettin any nd all air out of ur brake lines after fixing them?
question ive got a new problem with my brakes 1 the new master cylinder i got is different to my old one my old one was the rectangle shape n the new one is an oval shape is the any difference between the two beside the resivor. problem 2 after bleeding the brakes the pedal is back up where it should b but after the car is started i lose my brakes agian need urgent help??
you have to bench bleed the master cyliner before putting it on to the booster or the air will be stuck in the mastercylinder...do this by blocking off the holes were the brake lines go in then with a screw driver push the cylinder in and out then while pushing it in realease the wholes and air should come out
got master cylinder all sorted got all air out than when i started the car the pedal went again all the way to the floor but with car off its back up any ideas help needed urgently?
Does the booster hold vacuum ? with the engine off if you flex the hose connector to the booster can you hear air sucking in ( if yes then ok )
might need to bleed the brakes as well. The pedal should sink a bit when you start it but not go to the floor. good luck with it.
no real difference that i know of between the oval and rectangular reservoirs, the reservoirs and cylinders arent interchangeable though.
RE the pipe spanners, looking back I should have gone for better quality ones, the ones i have are OK but a better set would allow me to tighten the ferrule nuts with more confidence of not rounding em off.
Greenacc, from what you described RE the pedal travel with and without engine power your booster will be fine, bleed the brakes in order from longest line to shortest, let it sit for a day so that the tiny bubbles come together, these will bleed easier when you repeat the process the next day, make sure there's no fluid leaks from the brake lines or the nipples on the calipers. Failing that take it somewhere and get a professional to do it, not really a job to tackle if you dont know what you're doing.
To me it sounds like air somwhere to me. As said, bleed from rear passsenger side first then make your way to the front.
Q. Are you bleeding them properly, only reason i ask is i remember somone was on here before and they wernt closing the bleeder nipple(or bottle and tube) before lifting their foot off the pedal and sucking air back into each caliper as they done it.
thanks guys booster is working alright had the brakes working real well last night after bleeding them so ill rebleed them on saturday morning n leave it til sunday n bleed them agian. yeah im bleeding them the right way by gettin some1 to press pedal in and hold while i open bleeder than close it than tell them to release and press pedal in agian so will hav an update on how it goes on the weekend
