Results 1 to 21 of 21
Thread: One piece tailshaft...wtf??
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default One piece tailshaft...wtf??
    I thought all Commodores had a 2 piece tailshaft......but my VB has a 1 piece? Why would this be? Is it standard?
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Not sure if they are standard on the VB's, but some people put them on "performance" enginers, personelly I would be changing it, as ive seen the carnage caused by breaking, ripped the floor pan to shreds in a mint monaro. Also its known people to have rolled their car from one braking under huge acceleration.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    wats wrong with a single piece one? Wont it be very simular to a 2 piece one considering it just spins the diff? (im not savvy with tailshafts and im very curious)
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Fusion's Avatar
    Fusion is offline Awww I bent my wookie !
    1982 VH SL/X, 1997 SII Calais .
    Sep 2008
    Colac Vic.
    I would prefer a 1 piece tailshaft . If your worried about it breaking fit a safety loop .
    I think it would be less chance of breaking with less moving parts . there's not that much of an angle to really hurt the uni's .
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Paiste402 View Post
    As mentioned below, the safety loop/mounting bracket in the middle. If you look at how it works, ok theirs two parts,
    Front part - Closest to the tranny
    If the front uni snaps, then nothing it falls out makes a rattle and you entually come to a stop, if the rear snaps (the CV joint holding the two parts together) then the rear parts drops, front half is held safely by the safety loop, and the rear will just hit the road, very little chance of it doing damage.
    Rear Part - CV- Diff
    Front part as described above. If the rear brakes, its half the lengthto rip through the floor pan, and will most likely just hang down and spin, wont even hit the road.
    One piece tail-shaft
    If the front uni snaps, as above wont do much damage, though has more potential with it being twice aslong.
    rear - If the rear uni joint snaps, theirs no safety cradle or anything, and they are known to hit the road, and bounce up through the floor pan and tear it to pieces, and in some cases fling out, grab the road and flip the car (id like to see prove of this happening though)
    Quote Originally Posted by Fusion View Post
    BINGO!
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    ah thanks tom, mate u know nearly everything
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Close mate.... I KNOW EVERYTHING..... but rep given anyway lol jks..... Just have to much free time so spend reading car forums lol.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    single piece driveshaft means there is less to go wrong, no center bearing or C.V. to fail. if upgrading your drivesaft then there is no reason not to go with a sigle piece shaft.
    an old neighbour of mine told me a little story of someone who didn't do the 6 capscrews up properly that hold the 2 halves together. should these come loose or fail then the rear half of the shaft will fall down and hit the road, should it dig in it can flip the car. i always loctite em if i split a driveshaft.
    Body by Holden, Soul by Brock
    the Legend will live forever
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    All Commodores had 2 piece tailshafts.
    Oh and tom, if you know everything, you would of already said Commodores don't have factory 1 piece jobs.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Yeah - from the factory all Commodores had 2 piece tail shafts. Also from the factory a lot of Commodores had vibrations caused by the centre bearing. The simple fix was to eliminate the centre bearing and install a 1 piece tail shaft. I don't have any issue with them myself - Keep the thing maintained, fit a tailshaft safety hoop and make sure it's up to spec to suit whatever hp applicaton you are running and it will be fine. I think any tailshaft failure (1 or two piece) could cause a lot of un intended panel beating under your car.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VN Sedan
    Jan 2007
    Latrobe Valley
    with a one piece tailshaft if the front uni snaps the sharft drops down and can dig into the road....do that at even 100k's/hr and see what can happen. a mate had it happen in his valiant back in 1980 and rolled the car.
    Apr 2006
    Auckland NZ
    didn't brocky have a tailshaft failure at bathurst one year? i remember him coming down conrod straight with stuff flying around the cabin coming from the floor area
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by immortality View Post
    He had a VN one break on the start line once. That was in the very early 90's when they were way short of money. I sort of remember one like what you were talking about but thought it was either Win Percey or Alan Grice in a VL/VN/VP??? HRT car???
    Reaper
    Reapers Black VP SS
    Apr 2006
    Auckland NZ
    Reaper
    could have been, fairly sure it was HRT. had in car camera and there was a lot of debry fly'n around for sure. wouldn't have been nice trying to get it back to pit lane
  15. #15
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by SL/ENUT View Post
    It was a joke mate, As a said my knowledge doesnt go back far enough to know whata VB came out with, ive never worked on one.
  16. #16
    '85 HDT VK SS, '03 Liberty GT, '06 Forester XT
    Jun 2006
    one piece are no good for lowered old model commodores, they tend to hit on the floor when going over bumps, a two piece takes up the change in angle with the centre bearing.
    one piece do tend to be stronger because, as said less parts to break but they are really only needed when you have big power going through it. the std two piece can handle a fair bit
  17. #17
    Fusion's Avatar
    Sep 2008
    Colac Vic.
    I'm pretty sure it was brocky in a VL coming down conrod when the gearbox let go and was spitting teeth and other stuff into the cab . If i had the chance i would run a 1 piece tail shaft . Just bolt a strap of steel in a "U" shape near the front of the tail shaft so if it does break the strap will stop it from hitting the ground ...... used in most race cars now .
  18. #18
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    Yeah - from the factory all Commodores had 1 piece tail shafts. ..snip.
    Reaper
    huh..???
    think u mean 2 piece
    lots of reasons why GMH went 2 piece with the shafts on Commodores
    ...to overcome NVH, driveline angle, durability issues that came from the
    fitment of aussie engines and trans into the Opel designed chassis.
    and FWIW the 2 piece shaft is as strong as a one piece...and without the
    advantages the 2 piece gives. After all Brock Grice HDT etc used 2 piece shafts
    with the Grp C and Grp A race cars
    hth
    Smitty
  19. #19
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by Smitty View Post
    huh..???
    Duh... Yeah - original post edited.
    Nah. The only VL Brock ran at Bathurst was the 1987 race where 05 expired early (blown engine) and in the 10 car which he won. After that he ran the BMW and then Sierras before returning to the VN Mobil car (which broke it's tailshaft on the starting grid).
    Reaper
    Reapers Black VP SS
  20. #20
    DANNY8's Avatar
    Apr 2004
    Thx for the info guys. As soon as my new motor is built I'll be converting to manual so I'll prolly just take the 1 peice shaft out and put in the 2 piece which I got with the other motor and trans.
    The main thing I was worried about was having to drill holes to mount the centre bearing on the new tailshaft......but if all Commodores had a 2 piece well it should all bolt in no probs
  21. #21
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Quote Originally Posted by Tom_1569 View Post
    Ahhh, its all good. Didn't mean to sound harsh on what i said chief.
  1. Piece of Me??
    By Jecs in forum The Pub
    Last Post: 28-03-2008, 04:27 PM
  2. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  3. One piece tailshaft
    By bigal in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-12-2006, 12:50 PM
  4. piece of this?!
    By -davo- in forum Jokes/Humour
    Last Post: 11-06-2006, 08:00 PM
  5. 2 piece tailshaft V 1 piece
    By LindasBT1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2006, 12:34 AM
