are the wagon diffs different from sedans?
i would like to swap for a disc rear end, so does that mean i have to find one out of a wagon, no matter whether its a VK/L or even VN?
A wagon diff don't fit a sedan. They have very different shock mounting points. The wagon diffs have there shock mounts on an angle.
Yep, unfortunately.
that kinda sucks, so my best bet is to look for a V8 VL wagon diff then eh??
What about finding a normal VL wags diff, then using the brakes from a VN diff or sumfin.I'm sure they'd fit ok as both are borg warners.....but yeah not 100% sure. I'm in the same boat with my VK wags.
A mate has a VL Berlina and it has disk rear end. And we picked up a VK 2day which has had pretty much a whole VL transferred into it (motor, trans, interiour, diff) and that has disks as well.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
yeah, i dont have much knowledge at all when it comes to diffs. id just like to see an LSD and discs up the rear end. just figured it would be easier to do a straight swap, but maybe your right Danny, might need to do some mix and matching
did the VK/VL wagons ever come with LSD?
Only if it was ticked on the option list. Although here at home, i have a 10 bolt Sals 3.08:1 LSD out of a wagon.
umm sorry to hijack but would a vr diff fit in to a vk...i have a mate who has a vl and he reacons that it should.
It would, but way to long and the tyres will scrub like no tomorrow.
ok, so i dont know how easy its gunna be to find one out of a wagon, can you swap the entire centre out of a sedan? or they dont swap like that?
i could swap my drums for discs on the current diff as well yes?
Swapping centres will work. As drum to disc, that works as well. But remember, the axles need to have the right seal or it will leak.
what about the master cylinder for the brakes? is the current one alright or do i need one out of an all disc commodore? assuming the all disc commodores were different?
Some were 15/16 some are 1 inch master cylinders. Major difference is the brake booster, get a 4 wheel disc brake jobbie
