Results 1 to 8 of 8
Thread: LPG Problem - Need help soon as
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Default LPG Problem - Need help soon as
    Hey guys,
    Ok my car wouldnt start one morning. I turned the key and didnt hear the gas prime as is usually does. (A hissing sound followed by a CLICK from the vaporizer) There was no hissing sound and the click was very faint. I get home that arvo and it primed and started.
    Next day, same deal and in the arvo it started. Now today ive got no priming or starting at all, it just turns over even later on in the day. I want to know what the hell is wrong and get some parts cause a mate of mine is a licensed LPG repairer.
    Any ideas? Im guessing the vaporizer.
    Thanks, Paiste402
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Normally the clicking is a relay, so if u can't hear a click.....it's prolly a stuffed relay.
    That's what I'd be looking at first anyways.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    oh u mean the little box that sits next to it with the wires?
    It clicks, but its damn quiet and i cant hear the LPG rushing towards the front of the car to start.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    ok, the clicking sound is coming from the actual vaporizer itself. Does this mean that its getting a weak signal from the electronics or is the system screwed up?
    commsirac is offline Banned
    vx
    Aug 2007
    There is possibly an electrically controlled solenoid valve for your lpg supply that is in the gas line before the vaporiser/convertor. These can become sticky and or not work, perhaps it is only when cold that it plays up. Try removing the connection to it and cleaning it up. When you activate the starter the voltage it gets will be reduced and is possibly one reason as to why it may play up when cold. Try connecting the solenoid direct to the battery next time it plays up, it may just need the extra few volts to get it open and then be freed up. If this fixes it, then it may be worth "priming" the solenoid first before operating the starter.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    hey man i think ur right! I started the car today no probs since it was nice and warm this arvo. Well i will just have to see about cleaning it or something, might take it to my mate of mine.
    Thanks heaps mate, ur getting me on the right track
    SilverVH is offline Banned
    Nov 2005
    It will be that black box with the wires coming to and from it that is causing your problem, primer module box or whatever you want to call it. Easiest and cheapest way to rectify it is to raid the wreckers for another 1 as they are an expensive piece of equipment. They are also resin sealed so don't try and split the box in an attempt to fix it, as you will only **** it.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    Quote Originally Posted by SilverVH View Post
    thanks mate! i will get onto that when i can
LinkBacks (?)
  1. 01-11-2008, 10:10 AM
  1. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  2. vt problem
    By ralph_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2008, 02:14 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. VN problem
    By Anne in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2006, 01:49 PM
  5. is this a problem?
    By kymbo28 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2005, 04:12 PM
