i have just bought a vc vacationer as an unfinished project / first car for myself.
the car has vk lights and a vh grille, i also believe the front doors have been changed to vk and the same with the guards and bonnet but not 100% sure.
my question is can i put the vk front bar on without much trouble or will it require a lot of work to make it fit if the front is still vc?
any help apreciated, thanks.
You will have to modify the lower panel under the front bar to make it fit .The front doors from VB to VL are the same .Maybe take a trip to your local wreckers with a tape measure and check out the difference . Also ,the front lower panel is spot welded on not bolted.
