Results 1 to 9 of 9
Thread: vn diff will it fit
    VH SL Blue 202
    Oct 2008
    Question vn diff will it fit
    hey guys
    just want to know if a lsd rear axle from a vn ss would fit into my vh?
    im hoping to up grade to lsd and disc brakes
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    The Diff is wider then a VB-VL diff.
    You can use the brakes etc on certain diffs but need the axels shortene. I think its the Borg warners that you can interchange the brakes etc on.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VH SL Blue 202
    Oct 2008
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    TheVL Turbo diff is the better one being 28 spline over 25 spline.
    Not sure how the rear uni will go mating up, but its been done a heap of times.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    VL V8 diff is also 28 spline and more common than the VL turbo diff. Plus people don't ask huge amounts for it just cause its from a "VL Turbo" uleh. And they're the same except for diff gears.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by 1991_Vn2nV View Post
    Good point, there was an advantage to using the Turbo diff, but I cant remember what it was now. Maybe they share the right uni?
    VN Calais
    Sep 2007
    Your thinking of the gears I would say.
    VL Turbo diffs have 3.45 gears, VL V8 diffs only have 3.08
    Cheers.
    VH SL Blue 202
    Oct 2008
    SilverVH is offline Banned
    Nov 2005
    You can use a VN diff (which will be 28 spline axles anyway) but the widest tyre you will be able to run before running into scrubbing issues is a 205. You can get a VL sedan diff and use the internals from the VN diff and shorten each axle as a cheaper alternative, or you can just bite the bullet and find a VLT diff, upto you. If you don't mind being restricted to 205 tyres, then a VN diff is the way to go.
  1. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  2. question about diff gears in a irs diff vs 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2008, 04:21 PM
  3. VT-VZ IRS LS1 Diff will it bolt up to V6 IRS Diff cradle?
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2008, 09:51 AM
  4. WTB: 3.73 Diff Gears Suit VS Diff
    By Wagon_Wheel in forum Swap / Wanted to Buy / Trade
    Last Post: 11-08-2008, 02:51 PM
  5. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
