Results 1 to 9 of 9
Thread: LSD diff to fit injected 5.0l
    VK calais
    May 2006
    cranbourne
    Question LSD diff to fit injected 5.0l
    hey, i've just fitted an injected 5.0L into my VK calais.
    i need an LSD diff with preferably 3.08:1 gears.
    i want to just bolt it straight up without stuffing around.
    will a VN-S bolt straight up or will i need a VK-L diff?
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Bahhh This isnt really being asked again?
    No a VN-S Diff has a wider track, then the VK diff. This can be corrected with rolling the gaurds and the correct off set and heap of dicking around.
    The VK Calais will have 3.08 gears and some(not sure if all) came with LSD.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    The Darkness's Avatar
    The Darkness is offline Junk Yard Dog
    Charged VT V6 A4
    Nov 2006
    Ipswich
    vk or vl diff will fit. just a question, how hard was the conversion. thinkin of doin it instead of 308
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    vb 9 inch ... or find a vk v8 lsd
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by VLDavo View Post
    No Holden ever came out with a 9inch, its a Ford diff. Very commonly used on holdens, but requires abit of work to make it fit to.
    Shortened (depending on which one), Mounts changed, Handbrake cable, and you will also have ford brakes and stud pattern on the rear, unless changer... more work.
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    get a standard 'large' Holden salisbury to fit a VK 308..most came with a 3.08 ratio
    and get a LSD centre fitted (available for around $500 + fitting)
    that way ..no mucking around with funny widths or having tyres hit gaurds
    or having to change or mod tailshafts (as u do with VL/VN types or 9")
    hth
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    VK calais
    May 2006
    cranbourne
    Quote Originally Posted by The Darkness View Post
    just dropped the mnmotor in today. it has a T700 auto so i had to pannel beat the driverside chassis rail a bit. i needed a new gearbok cross member to fit but the engine just bolted into the original mounts. that part wasnt hard. just neeed to swap the battery and airbox over and get it wired. its not all that hard. it cost roughly 6000 because it had an EFI 6 so i didnt need to run new fuel line either.
    good luck with the conversion if you go ahead.
    thanks for the help. i will keep my eyes peeled for an LSD diff to fit.
    VK Calais 5.0
    Nov 2008
    Just a thought.....is the salisbury in a V8 VK the same internally as a HQ - WB salisbury?
    Might give you a cheaper option, just swap over the internals with a LSD center out of a ute.
    Hopefully some knowledgable bugger on here will know
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    If both Salisburys are 10 bolt(oval cover), yes that have the same internals. But, that said 10 bolt Salisburys are very thin on ground these days.
  1. My Injected 355 VL
    By VL 355 in forum VL
    Last Post: 31-01-2011, 05:39 PM
  2. vk injected 5l
    By burkey18 in forum General
    Last Post: 12-07-2008, 12:10 PM
  3. F.S. LSD diff, injected manifold, ecus and more PERTH
    By jamo25 in forum Parts And Other Items For Sale
    Last Post: 15-07-2006, 02:40 PM
  4. 253 injected?
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-08-2005, 08:09 PM
  5. Injected 5L into VK
    By blandyVK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-06-2005, 10:42 AM
