Results 1 to 5 of 5
Thread: VK conversion
    L67 vt series 2 calais
    Oct 2008
    Smile VK conversion
    Just need to know if i can be defected for putting a turbo in a vk if so how can i get around this and whats the cost on a conversion these days from auto to manual.
    The Darkness's Avatar
    The Darkness is offline Junk Yard Dog
    Charged VT V6 A4
    Nov 2006
    Ipswich
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Turbo - Yes its illegal, it needs to be engineered.
    Manual conversion - You can pick up conversions for cheap, but Id say atleast 300 would be a good start for parts.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    on a 202 or on the 5L
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    202injected's Avatar
    202injected is offline Quality Engine Builder
    VZ Exec. 3.6
    Oct 2005
    If your car is a 202, the turbo setup will deffinately need to be engineered and mod plated. there are a couple of legal registered ones here in NSW, and from what i have heard it is not that hard. The best way I know of is to use the factory EFI manifold, and use an aftermarket ECU, more chance of getting it passed than a carby setup. The factory computer can be used for very low boost as they run very rich in natural from, just plumb in a rising rate regulator. but any more than say 6 psi you will need to run an aftermarket puta.
    V8 will have the same legal problems for turbocharging, but there are a few companys doing kits for the EFI 5l, so just swap your head and cam and look at that option as some may already have EPA compliant kits
    I converted mine to manual, using a celica steel case ( on a 202, V8 you would probably better looking for a supra or T5) and dellow bellhousing for about 500. the hardest bits to get done was working out which clutch plate to use with standard pressure plate and finding a yoke to fit to the tail shaft. you will also need to locate a clutch pedal box, for a 6 this will be fairly easy, but if it is an 8 you will have trouble find a pedal box, and expect to pay for it too. keep in your mind the pedals are very different and cannot be intercahnged.
    HUNTERMOTASPORT
    Mild To Wild, Your Engine to Your Budget
    no more VK cancer got the better of her R.I.P.
  1. VK ute conversion
    By smickvn in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-12-2009, 12:01 AM
  2. V8 to V6 conversion
    By Starkey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2008, 02:35 PM
  3. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  4. V8 conversion
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2006, 07:42 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
