Results 1 to 5 of 5
Thread: Repairs to door
    1982 VH
    Oct 2008
    Unhappy Repairs to door
    Hi all, any one know of a manual that shows how to repair the ouside door latch?? I can open the door from the inside but not from the outside. Anything would be helpful.
    LightningVP is offline Donating Member
    None
    Sep 2008
    You have probably dropped the metal wire that opens the door...You will need to take off the door trim and put it back on, happened in my mums VL
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Quote Originally Posted by LightningVP View Post
    bingo, yea its just like a little hook. I could get into my old VB by pulling out the lock and pushing on the little hook. 'POP' the door will open.
    u will see straight away once u get in there.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    None
    Sep 2008
    If it is that your lucky...Cause there are some cases where the wires comes of the lock...so you can't unlock the door at all...So you can't actually take off the door trip on newer cars because there are screws...
    But yeah if you need help with taking off the door trim there is a hot-to on it, if its the same as VLs all you do it carefully pull it off, just has push in button things, no screws
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    1st you want to clip off the inside handle surround and lock surround (if you have slide locks, if you have screw ones unscrew the lock knob), then remove the inside mirror cover bit, then with a flathead screw driver slide it under the window winder and push the flat clip out (it will usually go flying), then you can pop off the winder. Unscrew the armrest and the whole doortrim will be free, you need to pop all the clips out around the bottom and side edges (very carefully cause they break) then lift the door trim from the top. Installation is a reversal of removal
    ^^ just incase you never had one apart hehe
    ========My Statesman 20's Mafless and 3.9's========
  1. Rim repairs
    By HIROLLA in forum General
    Last Post: 24-04-2009, 08:12 AM
  2. Body Repairs
    By 4PLAYN in forum The Pub
    Last Post: 11-09-2006, 07:51 PM
  3. PCB repairs
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2006, 03:41 PM
  4. mobile alloy wheel repairs done at your door step
    By TonyTheTyreTech in forum The Pub
    Last Post: 20-09-2005, 02:30 PM
  5. Mag Repairs?
    By jerome_boy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2004, 10:58 AM
