Results 1 to 6 of 6
Thread: VK Grp A clutch
    VK SS Grp A
    Oct 2008
    Default VK Grp A clutch
    I am rebuilding my VK GrpA Brockie and I have a problem with the clutch. The car was completely stripped but I wasnt the one who disconnected the clutch at the gearbox, (this car has a cable operated clutch, I believe standard road cars with manual boxes had a hydraulic clutch). Anyway I have had the box recoed and put in a new cable but I find that the peddle is all loose and I feel that there must be a return spring at the clutch somewhere but the guy who pulled it apart says there wasnt one. but to get the slack out of the peddle it would appear that there has to be a spring there. Can anybody help, please.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Now, AFAIK, all VK SS Grp As are a cable clutch, with the M21 aussie 4 speed manual gearbox.
    Sounds like the cable needs adjustment also, there is a spring on the clutch pedal, maybe thats off.
    VK SS Grp A
    Oct 2008
    cheers but the clutch peddle/spring has not been out of the car. the spring is not broken either.
    VK SS Grp A
    Oct 2008
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Quote Originally Posted by 58rabbit View Post
    When the clutch cable is released, it only takes a small amount of movement of the pedal to dislodge the spring. The spring usually hooks onto the pedal, at the end, there is a hook. It sorta keeps the cable hooked up really.
    As for an online parts manual, there isn't one. A member might have one, take a pic or scan for you.
    VK SS Grp A
    Oct 2008
    Cheers for that. I have been thinking about it and I think it's all about adjustment. I hope so anyway.
  1. vu ute clutch
    By ripper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2009, 10:26 PM
  2. vy 6sp clutch
    By gazza m in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-08-2008, 06:37 PM
  3. Which clutch kit?
    By Galixia in forum General Discussion
    Last Post: 08-08-2008, 02:25 AM
  4. VN/VS Clutch And VL/VS Clutch
    By cohn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-07-2006, 09:36 PM
  5. VN SS Clutch
    By dpac in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2005, 06:52 PM
Tags for this Thread
