Results 1 to 8 of 8
Thread: how to replace Exhaust Manifold on 308?
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Default how to replace Exhaust Manifold on 308?
    hey fellas, how are the kids?
    Nevermind, any way ive gotten a hold of a set of stock 308 exhaust manifolds from a commodore for free of a mate of mine and i want to change them over (since the ones on my car are well... cracked.). He had already taken them off and had them lying around for a while before i got there so i dont know how much these have been used.
    Now how do i go about this? Also i have put a ruler on the new manifolds and its barely out one millimeter at the most. Are these ok to put on or do they need to be machined? Also they dont look too old (ie not a strange colour from being heated up and cooled over and over). Is there a gasket where it connects to the actual exhaust pipe?
    thanks guys
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    no one at all knows how its properly done?
    Jun 2005
    yeah you can get gaskets for them. try supercheap or repco or something. should cost about $15 for a set
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    As Stocky set, Gaskets can be had fro most places, try and use the metal ones if you can, these are suppose to be better and more tolerable to not perfect faces.
    Have a look at your current headers, are they bolted to the motor and bolted directly under the header, or does the header have the exhaust coming down and joining further down, if so where and how is it join. I know some older headers had the exhaust going down to the Y-pice, which could mean cutting and welding, but some can be unbolted directly under the header.
    If its the easier type, then its pretty simple, remove old header, clean up the surfaces lightly with some 600 wet n dry, clean the threads etc to get a good clean fit. Whack the new one on with a new gasket, line up, torque it up. You can also use a gasket sealer aswell if you want, but I wouldnt worry if using the metal gasket.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    yea it just connects to the pipe via some bolts so no cutting needed. Well thats good on my behalf! Dont have to pay someone to do it now. I know that gaskets are needed to connect the manifold to the engine head (ive done it a few times now, i hate it lol) but rather how its connected to the pipe itself?
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Paiste402 View Post
    Should have two bolts and a flange?
    Unbolt the sucker, it may require a tap, pull it off, and clean up the flange and fit a new gasket their to. Though theres a few other different designs, if its not a flange whack up a pic.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    ya ur gonna need exhaust shop if they don't flange up to y pipe aye. I drove my torana to exhaust shop like this with a bad join LOL sounded like an aircraft
    ========My Statesman 20's Mafless and 3.9's========
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    oh no its got a flange there. So just unbolt, clean, gasket and rebolt. Sweet, thanks guys!
  1. Will this exhaust manifold fit..........???
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-04-2008, 06:51 PM
  2. manifold.. much to replace ??
    By Nicks in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2007, 10:57 PM
  3. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
  4. VR V6 exhaust Manifold
    By fitykemp in forum Parts And Other Items For Sale
    Last Post: 03-03-2006, 12:05 PM
  5. remove and replace exhaust manifold ov VL
    By dibly1980 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-02-2005, 07:31 PM
