Results 1 to 7 of 7
Thread: 202 heads
    maxpower QLD's Avatar
    maxpower QLD is offline has mild super powers
    Xtrail/5spd VL
    Feb 2008
    QLD (the police state)
    Default 202 heads
    Hi everyone
    I have a friend who's looking at buying a reconditioned stage 3 yella terra head off a red 202 engine to put on his blue 202 (3.3 ltr) VK engine (i think ?) and he seems pretty sure it'l be a strait swap but some how i'm not sure they are a strait swap , so can anyone confirm wther the yella terra head will fit his engine or not .
    Quote Originally Posted by VS Omega View Post
    "gonna beat you to the next set of lightes uleh"
    Fusion's Avatar
    Fusion is offline Awww I bent my wookie !
    1982 VH SL/X, 1997 SII Calais .
    Sep 2008
    Colac Vic.
    As far as i know you can't interchange the red motor heads with the blue and black motors .
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    You can put a Blue/Black head on a red motor. You need to use the blue motor gasket as a template and drill holes for water galleries.
    Not to sure about putting a red head on a blue motor, I doubt the advantage would be much, if any. Yes I understand a Yella Terra head is the bee's knees but its still a 9 port head compared to the 12 port head. He'd be better of spending the money freshening his head up. Also the red head wont comply with the appropriate emissions.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Oh will it fit?
    Yes it will physicalls fit and bolt up, but water galleries and **** wont line up at all, I guess you MAY be able to use a red head gasket and drill the appropriate holes, but I still dont think its worth it.
    Xtrail/5spd VL
    Feb 2008
    yeah i didn't think they'd fit with out some kind of modification being done first . The engine is in a WB holden ute but the engine originaly out of a VK (well so i was told) . The engine is still petty fresh , i think it's only done around 15000 ks since it was last rebuilt ( both the engine and cylnder head rebuilt - $1700 later) so maybe he might be better getting a cam instead then . anyways thanx for your help guy's
    202injected's Avatar
    202injected is offline Quality Engine Builder
    VZ Exec. 3.6
    Oct 2005
    it is possible and as stated holes will need to be drilled to suit. but there is no advantage, you be better off milling about .050" of the head, getting a mild port and polish on the inlet only then using flat top pistons and a 0.7mm gasket (ACL race series).
    The blue black head has the same size valves as the yella terra stage 3 with the benifit of 12 ports instead of 9, but has a larger chamber, hence the need to mill it off
    but doing this you should get about 9.5-10:1 compression which is heaps for a street car
    HUNTERMOTASPORT
    Mild To Wild, Your Engine to Your Budget
    no more VK cancer got the better of her R.I.P.
    VT spac super6
    Nov 2008
    Riverton sa
    The ports and studs on a red head wont line up for the manifolds for a blue head
  1. VN Heads
    By CarCare in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-07-2008, 11:44 PM
  2. Vn Efi V8 Heads
    By VL2Di4 in forum Parts And Other Items For Sale
    Last Post: 06-01-2007, 12:55 PM
  3. Which Heads
    By chappy in forum General
    Last Post: 17-12-2006, 11:50 PM
  4. VN heads on 308
    By atrail308 in forum V8 Development and Modification
    Last Post: 29-09-2006, 01:57 PM
  5. How much for a set of heads and a cam?
    By GROWLZ in forum LSx Development and Modification
    Last Post: 24-09-2006, 03:22 PM
