Results 1 to 7 of 7
Thread: Vt Starter on old 308
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    Default Vt Starter on old 308
    Well as the title says, I need a new starter motor for my Vh and ive been told i can use a VT 5lt starter as there better,
    but he said some thing about the bolts being diffrent sizes.
    Does this cause a problem? is it a straight bolt in with the right bolts?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I thought the blocks were all the same.....the VT is a hi torque starter so it is a better starter. Pretty sure it will fit.
    Visit my Facebook page
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    i would go the VT, not as old and would last alot longer than the VN or so. Also high torque means spins faster and better starts.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    SilverVH is offline Banned
    Nov 2005
    VN isn't the same as VT, VT is a gear reduction starter, you will need the bolts to suit, everything else is plug and play.
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    vn and vt have the same 304 engine i dont see why a vt would have a gear reduction starter ???
    SIR LS1
    the two ton go kart
    Nov 2005
    vn and vt do not have the same engine, the vt runs roller cam, roller lifters, is clearanced for stroker, uses a maf sensor in the intake, uses different style exhaust manifolds all in comparison to the vn.
    It is called taking a product and refining and improving it over time. The same could be said for an I6 from an EB compared to an AU...
    So that is why the VT uses a different starter motor, more improved and refined compared to a VN.
    Simple.
  1. starter motor
    By help commador in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2008, 10:58 PM
  2. removal of starter
    By Lowwwerd vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 10:11 PM
  3. Starter Motor?
    By Grennan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2007, 05:36 PM
  4. starter
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2007, 10:51 PM
  5. VG ute starter motor
    By oldsurfiepete1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2006, 12:58 PM
