Okay you know the small apartment box inside the car that opens the boot via a button (opposite side to the steering wheel)? well when i closed the lid and tried to open it again to press the button to open the boot........ The lid wont open
I tried placing my key in the lock, but nothing.
Does anyone know how i can fix it? All i want to do is open it.
tried giving it a bit of a wack? that helps most things?
I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
vp ss 3 months to go
im stumped then
Can you squeeze the bits on the lock? like push both the buttons in?
If you cant then it may have locked itself, so find the key (main ignition key with the rubber) and try and turn it.... Other wise you MAY be able to snap the lock out without damaging the glovebox, because its only a very brittle clip holding the lock on to the glovebox.... alternativly, go to the wreckers and practicing breaking into one, until you find a technique that works![]()
Id say the left button is broken. You can use a screwdriver, to try and snap the clip thats holding the lock inplace. If you snap the back off, you wont be able to close the glovebox until you get a new lock and clip though.
Also pressed the buttons in, and try and wiggle the lock side to side, whilst pulling, you may get enough free play to wiggle it out if one side is still coming out.
If u pull the ashtray out, aircon switches and cd player.....u might be able to get a screwdriver in to push the pin out, which holds the whole glovebox in. I can on mine, but I've removed a few things so not sure if it can be easilly done on a normal car......it will still be locked shut, but atleast then u should be able to break the lock and not the glovebox.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
This is exactly what happened to my glove box, im guesing the lock is stuffed so i just got a flat head screw driver and wedged it out until broke off the little clip from the back, i had another lock that i put back in straight away. But be careful as you can scratch the plastic on the glovebox and also risk breaking the glovebox itself. If you want to try this way its up to you but i dont wanna be blammed for any misshaps![]()
Red 1985 VK Berlina Commodore
