Results 1 to 18 of 18
Thread: 202 VH 5spd. Transmission woes..
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Default 202 VH 5spd. Transmission woes..
    Ok, so since I bought this little bugger the tranny has made some pretty kick ass sounds, except for in 4th. It behaves perfectly in 4th...makes sense I guess since it's a straight thru in 4th.
    I'm definetly looking at an eventual bearing failure in there, but since I do really have the resources at the moment to yank it out and rebuild the bitch I've often thought about draining it and dropping something thicker in there. But, it has Dexron in there at the moment so I'm not really sure what I should drop back in. Any ideas? Was thinking perhaps some 50 weight motor oil?
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Tasmaniak's Avatar
    car
    Apr 2005
    Yes it is.
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    You should be using SAE80-90 gear oil. Dexron will kill it in no time flat.
    Tasmaniak's Avatar
    car
    Apr 2005
    The Borg Warner 5spd had Dexron in it from the factory. It even says so in the owners manual...
    I guess I need to look for help elsewhere.
    Sep 2005
    Newcastle
    Ok I'm slightly confused you state you have a VH 202 5 speed. This transmission must have been fitted to the vehicle later as 5 speeds were only fitted to 173s in VH's. The gearbox fitted to the VH 173 was the M75 which used dexron fluid. Five speeds were not used behind 202s until the VK. This transmission was the M76 and used 80/90 gear oil.
    In answer your origonal question. Using a thicker oil will slightly muffle shagged gears and bearings. Ultimately if the things had it, its had it, thicker oil wont make it last longer.
    Tasmaniak's Avatar
    car
    Apr 2005
    Yeah mate, I'm hella confused myself now...I've had the car two weeks right? It's definetly a 202...block is stamped 3.3
    Build plate shows engine as 3.3 and transmission as a M76....but she is definetly a VH.
    I understand what your saying because I visited a website that had the specs on all the cars and it listed the M76 as being the 5 speed but not available on the 3.3 ?! FIIK what I have now.
    Yeah, the idea behind the thicker oil was to shut it up a little bit till I decided what engine and trans combo I wanted to put in.
    Here is that website...
    http://www.uniquecarsandparts.com.au...ifications.htm
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by tigervh View Post
    The VH 173's used the M76 as well as the VK 202's. I've never heard of an M75? My VH was a 173 5spd, and the plates matched, can't remember the motor code, but I know for sure the trans was M76.
    Tasmaniak's Avatar
    car
    Apr 2005
    Everything just added up....Just went out and looked at the build plate
    Engine: LD1 Trans M76 (I was right on that one) Axle: GV4
    So basically it's had a motor swap done at some point in time I can handle that. the manual still says though that it takes a DEXRON fluid and I checked the trans and thats definetly whats in there.
    Sep 2005
    Newcastle
    Interesting, the factory manual I have for M76 states 80/90, also the recomomedation on the castrol website is 75/85 for M76.
    If you look on the castrol recommendation site For VH it states transmission is M75 and Lubricant is Dexron, if you look up the VK it states the transmission is M76 and the lube should be 75/85. Also have a look at the note on the VH recommendation.
    Here's the link. Castrol Australia - NetLube I can't post a direct link because it is an applet.
    Tasmaniak's Avatar
    car
    Apr 2005
    cannot get that link to work for me at all...tried several different ways. perhaps it will work a little later or something.
    So now what the bloody hell do I do? I guess I could always drain it and refill it with 80w90 and see what happens? I mean it doesn't use the detergents in the DEX just the viscosity. So upping it that far won't do too much damage UNLESS it cannot spin the synchros fast enough in time for a gear change.
    Sep 2005
    Newcastle
    Quote Originally Posted by Tasmaniak View Post
    You have to enter the vehicle details in the drill down field. Your browser will need to be set to allow Java script.
    Tasmaniak's Avatar
    car
    Apr 2005
    dunno mate, it's working now. I kept getting a page telling me I wasn't connected to the net. I'm convinced that I'm just going to dump some 80w90 in there and call it quits.
    Sep 2005
    Newcastle
    Doing the bearings isn't as expensive as you might think. If you strip the box and record the numbers on the bearings. Companies like CBC or Bearing traders will supply replacements for a fraction of the price Holden will.
  15. #15
    Tasmaniak's Avatar
    car
    Apr 2005
    I know this but it's a case of finding the time plus I'm still waiting for my tool cart to be shipped back over to Australia from the US which is going to take a month if not more.
  16. #16
    commsirac is offline Banned
    vx
    Aug 2007
    I have a box that was rebuilt but the synchro rings wouldnt work when it was cold, the persons rebuilding the box just decided to put the trans fluid in to see if that would fix it. I wasnt too impressed but it fixed it, and they came to the party and doubled the warranty rather than take it apart again to find why it wouldnt work with the specified fluid.
    Its done 200 000km+ with no problems so tranny oil in a manual box cant be altogether a bad thing.
    I dont think putting engine oil in there is a good thing, tranny oil and gearbox oils are designed with much bigger shear force factors etc(havent checked the numbers but thats what I was told).
    Try the gear oil as a way to quieten it down, if it works and the synchros are okay when its cold(or perhaps you dont mind double clutching) then it may be a good thing.
  17. #17
    Tasmaniak's Avatar
    car
    Apr 2005
    well, I live in broken hill at the moment and intend to have it rebuilt by the end of summer so cold boxes won't really be an issue
  18. #18
    vx
    Aug 2007
    cold as in below operating temperature.
  1. VN woes...
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2008, 12:37 AM
  2. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  3. ac woes VL
    By mattheman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-12-2005, 05:09 PM
  4. VN aircon woes
    By headbanger in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2005, 09:07 PM
  5. Petrol Woes
    By adamtuba in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 06:59 PM
