point breaker ignitions factory setting is 6 deg BTDC
Electronic ignition is 10 deg BTDC same as EFI engines
as for the question about "ported" or "full" vacuum. HX ie 1977 was the first to have the "ported" vacuum system prior to that EPA law change "full" vacuum was available.
BUT.. Just to clarify abit, full vacuum is available on all holden V8's. But from 1977 on, a ported system was also added. Through a series of thermostatic switches ( where the vacuum hoses go to the fittings in the cooling system) the vacuum is ported while the engine is cold and full vacuum is given once the engine has reached operating temperture. Models with electric choke also have an electrical switch which is mounted near the carby on the manifold. This why it is extremely important to make sure you run a thermostat in you car, cause if you dont your engine will never reach full operating temperature and stay there.
HUNTERMOTASPORT
Mild To Wild, Your Engine to Your Budget
no more VK cancer got the better of her R.I.P.
