Results 1 to 6 of 6
Thread: VK 304 not starting (fuel pump?)
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    Default VK 304 not starting (fuel pump?)
    Hey guys, I can't get my VK V8 started after tinkering with the mechanical fuel pump yesterday. It was running fine but when I put the fuel pump back in and tried to start it, it wouldn't go. It's got spark,compression, etc etc But I keep cranking it over and nothing happens, I've put fuel in the carby and it just burns that off and dies again.
    What could possibly happen to the pump to make it fail?
    Oh and is there another fuel pump in the fuel tank or is it just the mechanical one that is attached to the timing cover?
    Could low fuel level in the fuel tank cause this problem?
    VP Executive 5ltr
    Oct 2008
    campbelltown
    Quote Originally Posted by Pav View Post
    if it starts when you put fuel down the carby i would say that it is not getting any fuel to the carby Could be your low fuel level in the fuel tank or maybe it just needs a new fuel pump
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    There is your problem.
    Feb 2007
    WA Perth, Joondalup
    Yeah but all I did was remove it, replace the gasket, and straight back on. Apparently it is a new pump as well. Does the lever have to go in a certain way?
    Tasmaniak's Avatar
    car
    Apr 2005
    yes...it certainly does! Look inside where the lever goes and you will soon work it out. hances are yours is sitting under the lobe/cam
    Tasmaniak's Avatar
    car
    Apr 2005
    or is it supposed to go below it and you put it above? Don't really remember now. lol
    But I got $20 that says you re-installed it wrong.
  1. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  2. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  3. VT S Problems starting when i put fuel in...?
    By Swiftee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2006, 07:05 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
