Results 1 to 4 of 4
Thread: relocating the battery to the boot
    VK calais
    May 2006
    cranbourne
    Question relocating the battery to the boot
    i need to move the battery to the boot as it no longer fits in the engine bay.
    has anyone done this in a sedan and if so do you have any pics of the install as i need an idea of how to secure the battery. im using sealed battery so it doesn't need a box. also i am tossing up whether to run the +ve cable under the car or through the firewall and in the cabin. does anyone have any suggestions
    commsirac is offline Banned
    vx
    Aug 2007
    Run it in conduit under the car. Cable big enough to do the job is going to be hard to manipulate, cause nasty bulges in carpet etc as well as you'll avoid having to worry about a short on the firewall.
    LightningVP is offline Donating Member
    None
    Sep 2008
    I had the same idea, but also had the idea as putting an EXTRA battery in the car for stereo...
    My plan was to weld a metal frame in the right hand side of the boot and sit the battery inside that and hide it.
    Then run the positive wire under the car, but didn't actually plan where abouts under neath
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    In my wagz I ran 3x 4ga cables from the back to the front, inside the car, under the carpet. It has a little bulge, but nothing to serious. I've only got 2 connected and it starts with no drama's...went a bit overboard with a 760CCA battery, but yeah it does the job.
    I put all 3 cables together and put them in Narva split tubing, and put bracket things over the top to hold it in the right position.....easiest way to show ya is a pic.
    It's only like that until it goes under the carpet, from there the cables just run next to each other up to the front. They run along the passenger side of the trans tunnel. The hole I used to run them through the firewall is a hole which is already there, it's on the passenger side of the trans tunnel....so they pop out just behind the starter motor.
  1. Battery in boot - ventilation requirements
    By DANNY8 in forum Electrical Wiring / Questions
    Last Post: 24-09-2007, 11:45 PM
  2. battery in boot problem
    By Snotty in forum Electrical Wiring / Questions
    Last Post: 01-10-2006, 10:43 PM
  3. Wanna move the battery to the boot
    By immortality in forum Electrical Wiring / Questions
    Last Post: 20-08-2006, 01:49 PM
  4. Battery in the Boot?
    By Tekka in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-02-2006, 06:10 PM
  5. Replies: 10
    Last Post: 28-11-2005, 09:09 PM
