Results 1 to 4 of 4
Thread: 10 bolt Sals question (regarding spools)
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    Default 10 bolt Sals question (regarding spools)
    Hi, I was just curious, because I heard some rumours just wanted to confirm.
    Is it possible to fit a spool into a 10-bolt Sals even though it is an LSD?
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Yes its possible, can be done with other diff's cant why the 10 bolt couldnt.
    It would be a waste of time though, the LSD is a very good idea, you would be better grab a single spinner and molest that with a Spool, but its up to you. Theres more to it then that, have a search.... Im out, my caffeine has run out and 5hours sleep in 3 days has destroyed me.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Feb 2007
    WA Perth, Joondalup
    Another idea I had is to swap diffs with a mate's 253 HX kingswood wagon. Would it be an easy swap? Reason is he has 3.66 gears or somethin like that and an open spinner so it would be perfect for a spool. Just need to know if his diff will bolt into mine and vice versa?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the early commodore V8's had the large salisbury 10bolt diff. the HZ will have the banjo diff. these are different and not a straight swap.
    the salisbury only ever had a 2 spider LSD and these are fairly weak (unless you have the aftermarket 4 spider conversion which are now available in australia.
    assuming your talking about a fullspool in which case you would remove the LSD centre and then fitthe spool in it's place
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Mini spools
    By vsII manual in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2010, 03:30 PM
  2. vk 10 bolt sals axle length???
    By joshcrimmins in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-02-2007, 01:17 PM
  3. Mini Spools
    By Benji in forum General Discussion
    Last Post: 17-01-2007, 12:09 PM
  4. bolt for t5
    By VN-88 in forum The Pub
    Last Post: 27-04-2006, 10:10 PM
  5. spools
    By riss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2005, 10:36 AM
