Results 1 to 11 of 11
Thread: Vh not starting
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    Default Vh not starting
    I have this problem with my vh where ill start it first thing no worries drive it around for a while park, go back 30 mins later and i turn the key and there is nothing, all the dash lights will come up but nothing happens when i turn the key.
    If i fidle around with the gearbox lever go threw p,r,n,d then back up it will start no worries but not everytime. Sometimes ill just turn the key 5 -10 times and it will start.
    Ive had a bit of a look at the gearbox wiring thinking it might be the neutral switch not allowing it to start and it all seems to be good, could it be anything else like the starter motor? and what exactly should i be looking for wiring wise?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Check all the contacts and terminals from the battery to the starter motor.
    Its possible that its not completly slipping into park when you do stop it.
    Also have your ignition looked at, Might be a faulty barrel
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    well hopfully picking up a new starter motor this week so hopfully that fixes the problem
    2008 VE V6 Calais-V & '95 BMW 540i
    Jul 2006
    Melbourne, Vic.
    Most likely not the starter. I had this problem with the VH I had. It turned out to be the ignition barrel. But it could also be a dickie ignition lick out switch on the tranny.
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    ok well had a bit of a play around today found out when it doesnt want to do anything i can chuck it in neutural and it will start so far its started in neutral everytime. Is there a switch or wiring that could be playing up?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Sounds like the neutral start switch. The thing that stops the car starting in gear.
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Put a new one in. Take the console off and you will see it on top of the bracket. One screw I think is all that holds it on. Or it could be two.
    Visit my Facebook page
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    ok i took a picture cause im not to sure what im looking for
    is it the green thing?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep, thats the one. It operates on the pin that runs up through the stick. That one is just clipped on.
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    cool i shall pull it off and go to coventrys
  1. car not starting
    By panda88 in forum Car Audio
    Last Post: 29-05-2008, 03:10 PM
  2. 5L not starting
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2008, 11:59 AM
  3. starting the old vn
    By haynze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2006, 08:50 PM
  4. starting a vn without a key?
    By dave.b in forum Electrical Wiring / Questions
    Last Post: 01-03-2006, 09:06 PM
  5. vn not starting
    By vn4play in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2005, 05:30 PM
