Results 1 to 4 of 4
Thread: VK Dash.
    85 VK Berlina
    Jun 2006
    Default VK Dash.
    Hi guys,
    My VK is now on the road (will put pics up soon) but i still have a few problems that need to be fixed. Firstly my Taco (revs) doesn't work, my pedometer (km) doesnt work and also my fuel guage. Just wondering how i would go about fixing these and where should be the first place i should start looking? I have read on here about fixing the pedometer with a new gear for in the transmission, where can i get these?
    Red 1985 VK Berlina Commodore
    the lightning
    Jun 2005
    under the Southern Cross
    Tacho and fuel gauge; check wires from coil and condition of contacts in main engine harness. you'll have to trace the wires and check for poor connections back to the instrument.
    speedo gear for in trans?
    first check that the cable turns OK then get someone to sit in the car and watch the speedo for movement as you turn the cable with a power drill from the trans end. if it works then your dash is OK,
    then check the gear that's inside the extension housing of the trans on the output shaft to make sure the little retaining clip is properly engaged.
    you can get speedo gears from the wreckers, get the right colour one off the end of a cable out of a trans if needed.
    Quote Originally Posted by one_and_only2004 View Post
    Sounds like you and your friend have a collective intelligence rivalling that of a door knob. Looks like the useless crap you fit to your car is the driver.
    VR Commodore Exec
    Oct 2007
    Ballarat
    85 VK Berlina
    Jun 2006
    Thanks for that mate. Ill wait for a clear day and then ill see what i can find.
  1. VK Calais digital dash to analog dash
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2008, 08:16 PM
  2. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
  3. vh standard dash to sports dash
    By pjn963 in forum Electrical Wiring / Questions
    Last Post: 24-07-2005, 11:32 PM
  4. Changing a VP standard dash to a Tacho Dash
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 01-07-2005, 11:35 AM
  5. Custom Dash + Coloured Dash Lights?
    By ViperVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2005, 09:08 PM
