Blew the manual gearbox on my VK. Had a spare auto box which i put in.
Drove fine for a day. Now it has lost drive. Will move about 10ft before stopping??
Oil looks good, no leaks, no obvious faults etc??
Not an auto fan and am at a lose. Any ideas??
Gary
Here's a good way of checkin it out, just jack up the rear tyres of the ground
and leave it in neutral then put it in drive and check to see it the tyres start turning
If they turn then hit the accelerator slowly then increase as you go and listen for
any cracking/hissing sound coming from the gearbox or the camshaft
If this dont work then check the alignments inside the gearbox. If she jumps to hard
when slipping into drive then gears are either out of line or need to be degreased,
clean to shine and refill the transmission oil with the specified oil.
This prob has happened to mine, wrong transmission oil was used
If you blew the manual G/B then the shaft may be twisted and need replacing
Could also be the torque converter maybe?
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
The trans cooler lines might have been full of crap so it has blocked the filter inside the trans. The only way to check it is to remove the sump from the trans which will drop all your trans fluid out.
the flywheel might be stuffed and needs replacement
hey i know u goy ur problem but i was just wondering does any1 know ...i have a auto vk and i put transmission fliud in it and it uses it or sumthing because i cant see it leaking ...but when i put transmission fliud in it it runs perfect its a vk execitive with lows ks it jusst has this little problem any help please???
hwlp im a girl dont know much aye???
are you sure its not the bands in the auto box.. i had trouble with the auto in my vk before i converted it. if you drive it with the 1,2,3 select it stretches the bands out till it will stop movin..
