Results 1 to 4 of 4
Thread: vh problem...
    VH SL/E
    Jun 2005
    Default vh problem...
    vh sl/e with black 308.....after a 6 hour drive battery light came on...volts are fine still sits around 12...starts fine...under acceleration light dims to pretty much off so seems alternator is charging... someone enlighten me please
    VH + VK Gas Cars
    May 2004
    Alternator should be charging about 13.8V, 12V means under charging.
    Could be:
    1) Loose fan belt
    2) Bad Wiring from Alternator
    2) Shagged Regulator in Alternator
    3) Shagged Alternator
    4) Suspect Battery
    VH SL/E
    Jun 2005
    battery water was low toped it up n was all good light went away..drove 30 mins. volt meter startd dropping to 8 volts so guess alt has **** itself ....price and where can i get 1....oh yeah i'll need one 4 a black 308 is therea dfference between black blue and red....
    VH SLE
    Sep 2008
    Hastings Vic
    pull the alternator out and check the brishes and diode pack befor replacing the whole lot, they are heaps cheaper than a new unit.
    Ingrams stock most of the parts required to rebuild them.
  1. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. VN V6 LPG problem
    By joe b in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2006, 10:58 PM
  4. PC Problem
    By Sabbath' in forum The Pub
    Last Post: 25-09-2006, 05:16 PM
  5. Possible ABS problem, help please?
    By Spyper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2006, 02:34 AM
