Results 1 to 7 of 7
Thread: VK EFI - Rev Surge Problem
    VK 3.3i, V6 VL in Production
    Apr 2006
    Bathurst NSW
    Default VK EFI - Rev Surge Problem
    Hey y'all,
    Have an EFI VK and when I start it cold or give it a sharp boot (Even if cold or warm) the revs surge and eventually stalls if I don't put my foot on the throttle.
    This only happen at idle and otherwise runs fine. It doesn't use more fuel than it should nor does it run hot.
    I have changed all filters, air and fuel and checked over the inlet and exhaust and their doesn't seem to be any leaks.
    It has no oil leaks, the front seal and harmonic balancer has just been changed and no other leaks are apparent (thought there might have been a crank case pressure prob).
    Any ideas???
    Ted
    vh wagon/efi 202 off road car
    Apr 2008
    tacho relay or dirty air sensor (the swinging one) just after the aircleaner, I forget the name
    Apr 2006
    Bathurst NSW
    Apr 2006
    Bathurst NSW
    Thaks to newtownbob, you were spot on mate. i went into repco and priced a new air flow sensor at $250 so I bought some contact cleaner, I thought a non-residual evaporative cleaner would be the shot and it worked a treat. The car no longer surges its revs, power is noticable better.
    Well done
    Apr 2008
    VK Calais
    Dec 2008
    Drouin, Victoria
    My VK EFI 202 has the same problem as what yours has. I have to give it some throttle when I start her up, otherwise it'll stall. Probably the same reason?
    Power is noticeably better?
    vk calais
    Mar 2006
    hey dude.I had the same problem with my 202 efi run fine give it some it would cough then die.I changed the head and EFI manifold and that solved my problem.Lets us know how you get on with it.
    frost
  1. Fuel Surge?
    By kenoath in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-04-2008, 07:35 PM
  2. vp surge tank help please!
    By gee38l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 01:27 AM
  3. Idle Surge
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2007, 11:44 PM
  4. Engine Surge
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2006, 10:48 PM
  5. WH statesman Surge or miss problem
    By Daholdenman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 04:08 PM
