Results 1 to 2 of 2
Thread: Aussie 4spd rear seal
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default Aussie 4spd rear seal
    Been trying all afternoon to chuck a new seal in the back of my aussie 4spd. The mangled up one which come out has a rubber outter, but the only replacements I can find have the metal outter. The rubber stuffed one goes back in ok, but can't get the new metal ones going in. I stuffed one up, and the 2nd doesn't wanna go in either.
    My bro asked the mechanic at his work and he gave me a special tool to use, but still can't get it in.
    It seems the hole it goes in is slightly 'out of roundness' in one spot, like the trans was once dropped or sumfin. (see pic attached).
    Any ideas on how to put the thing back into shape? Oxy to heat it up and hit it maybe??
    Attached Thumbnails Attached Thumbnails Aussie 4spd rear seal-dscf4015-640x480-.jpg   Aussie 4spd rear seal-extension_housing_diagram.jpg
    DANNY8's Avatar
    Apr 2004
    Ended up putting a slice in the outer steel piece of the seal (so it could bend in without putting the rest out of whack). Didn't think it would of worked but it's keeping the oil inside the box so for now she's all good.
    When I pull the motor and box out next I'll just pull the extension housing off and grind or file it back, should be all good then.
  1. Rear seal oil leak
    By SDGVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2008, 08:00 PM
  2. Rear Seal - rear of automatic transmission
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2008, 02:48 PM
  3. vr rear seal into a vn
    By markovr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2007, 08:21 AM
  4. What rear main seal to use in hot 253
    By Mattie77 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2005, 05:20 PM
  5. Rear main seal on 5 ltr
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2005, 10:19 PM
