Results 1 to 2 of 2
Thread: VK ground locations
    VK Berlina
    Jan 2009
    Default VK ground locations
    Hey guys, I'm running two grounds from batt - to chassis and from engine block to chassis anyone got pics or can describe the best location for each in a VK?
    I'm guessing grounding to the chassis/frame is better as its solid compared to grounding to sheet metal/firewall area? Am I right?
    Also from engine block what is the best bolt to use that doesn't hold in and oil/fluid? A mounting bolt?
    Cheers.
    EcotecVK is offline Building it now...!
    VK EXEC 3.8L - VB SL/E 4.2L3 - VC SL/E 5L 4 spd
    Feb 2006
    Earth
    Earth your block, Starter and Body, and you will be fine. Also to get best earths to other coponents, try to earth them to the same bolt on the body you used to erth. Also remember - Bad earths eat your radiator!
    VK SL with VS Ecotec V6 and 5 speed Conversion (Ex 202 and 4 speed)
    VB SL/E 253 auto - Written off by blind old bat who can't see stop signs.
    VC SK 5L 4 speed manual, VL Turbo Diff - (another) blown aussie - intention is for Chev, 6 speed and ford 9 inch, and donate the VL Turbo diff to the VK.
  1. Cop Locations.
    By vy_berlina03 in forum The Pub
    Last Post: 13-12-2008, 12:21 AM
  2. Proper Jacking Locations
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2007, 03:09 PM
  3. Vk & Vl Chassis & Engine No Locations
    By TEMPA1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-12-2006, 08:49 PM
  4. Chasing Vl prices and locations
    By Alex_Vl_com in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-10-2006, 04:33 PM
