Results 1 to 4 of 4
Thread: 3.3 cylinder dimensions
    mightyredvc's Avatar
    mightyredvc is offline feel the fury
    83 vh sl/x (mid build)
    Oct 2005
    hobart
    Default 3.3 cylinder dimensions
    I was wondering if anybody had a copy of the haynes repair manual (or similar) for the vb - vk series. i seem to have lost mine and really need the cylinder bore dimensions and tolerances for the 3.3 blue. it seems pretty square but i need to know if it needs to be bored before i go and buy new rings for the ol girl. thanks heaps if anyone can help...
    commsirac is offline Banned
    vx
    Aug 2007
    For the 3.3L vb/hz red motor: bore:92.08-92.15mm, maximum taper 0.13mm, max ovality: 0.08mm
    The pistons to go with that are are: 92.055-92.131mm
    This is assuming its the same for a blue motor, couldnt imagine that it would be any different. From what I know the only real differences in the bottom end is the crank is better balanced.
    Oct 2005
    hobart
    thanks heaps. exactly what i wanted. she don't need boring!
    max taper = 0.02
    max oval = 0.01
    guess HM got it right 20,000 kays ago!
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Probably one of the only things HM Gem would get right. One thing make sure each bore is the same size. I have seen a V8 block bored by Gem that was .030" out from the smallest to the largest bored.
  1. VN-VS Sunroof Dimensions
    By Marcho in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 09:10 PM
  2. HF 3.6L V6 overall dimensions
    By grobb284 in forum V6 Development And Modification
    Last Post: 07-11-2008, 10:07 PM
  3. v8 dimensions
    By gregstar in forum General
    Last Post: 01-07-2008, 10:02 PM
  4. 308 dimensions
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-08-2007, 07:00 PM
  5. 2 Dimensions
    By mrc25381 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2005, 07:11 PM
