Results 1 to 3 of 3
Thread: VK RB30e transplant
    VK royal
    Feb 2009
    Default VK RB30e transplant
    Iv recently dropped an Rb30e and auto trans into my VK, have used VL cross member VL power steering rack and have VL ECU and wiring loom and am wondering how to go about adapting that to the rest of the cars wiring, also what the easyest way to mount back end of gearbox as the bolt holes don't line upand also wondering where the wires coming off the gearbox connect to????????
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Was your car EFI before??
    as for gearbox mount what gearbox are you using?
    If the VK or VL one doesnt fit then its pretty much going to be fabricate one up. have a look at my site at the gearbox mount I used. Mine was done in such a way I am able to use factory type gearbox mount and easily change it over.
    Other prople have welded brackets onto factory ones to make them fit or weld one up out of angle iron.
    cheers
    Scott
    VK royal
    Feb 2009
    Yes it's EFI, the gearbox is factory VL one the mount is about 40mm out of factory bolt holes, mount is also lower on one side
  1. RB30e ECU confusion
    By Krullos in forum Straight 6 Development And Modification
    Last Post: 28-08-2009, 10:34 AM
  2. rb30e in a vnbody
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2008, 10:46 AM
  3. Vl Rb30e to 308
    By TURBO_VK in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-05-2007, 07:25 PM
  4. how much hp will a standard rb30e take??
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2006, 06:43 PM
  5. Rb30e F.s
    By coolvl in forum Parts And Other Items For Sale
    Last Post: 31-08-2005, 11:07 PM
