Results 1 to 6 of 6
Thread: vk tacho problem
    worked_vk's Avatar
    worked_vk is offline Wet is 'PLAY TIME'
    VK 1984 Berlina
    Feb 2009
    Rockhampton
    Default vk tacho problem
    Hey everyone... just got a problem with my rev tacho and gauge in my vk.. its like its on a preset mode still. it only stopped workin after i got it converted from a 3 spd auto to a 4 spd.. so if anyone can give me advice on wat to do or look for.. thanks
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    have a look at my site i have wiring diagrams. What you need to look for is the wire that goes fromt he coil tot he tacho odds are its not connected somewhere. from memoryt he wire is brown but check the wiring diagrams.
    That may have bumped it off the coil when they pulled the auto oil dip stick out.
    cheers
    Scott
    worked_vk's Avatar
    VK 1984 Berlina
    Feb 2009
    Rockhampton
    worked_vk's Avatar
    VK 1984 Berlina
    Feb 2009
    Rockhampton
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Fluttering?? maybe it thinks its a butterfly :P
    Um just guessing here without a good description, vacume leak make sure they have properly blocked up the auto vacume port ont he carbie or EFI manifold.
    cheers
    Scott
    worked_vk's Avatar
    VK 1984 Berlina
    Feb 2009
    Rockhampton
    yeh they have done that wen i got my carby rebuilt.. only once i put that wire on the coil does it do that (brown wire) does it coff like its gettin air in the head or somethin.. wen i take it off its fine
  1. tacho problem
    By qik42c in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-07-2008, 08:26 AM
  2. Vq Tacho problem
    By VStooDie4 in forum Electrical Wiring / Questions
    Last Post: 08-03-2008, 05:47 PM
  3. VK Tacho Problem
    By philbio in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-02-2008, 06:52 PM
  4. Tacho Problem
    By brock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2005, 11:23 AM
  5. VN tacho/electrical problem?
    By H00LiGaN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2005, 06:47 PM
