Results 1 to 10 of 10
Thread: Vh sle heater problems no face heat
    Vh sle 5ltr 83
    Mar 2008
    Default Vh sle heater problems no face heat
    yeah when i turn the heater on i get no heat coming from to the face the feet and dimster work fine dono whats happening any help is good thanks
    also the heater core doesn't flow freely if u use a hose with lots of pressur then it does but other than that it doesn't also there is no rust
    CSD
    CSD is offline
    Oct 2003
    Vh sle 5ltr 83
    Mar 2008
    CSD
    CSD is offline
    Oct 2003
    you can't fix it. you can't get heat through the centre vents in any vh ever made.
    Vh sle 5ltr 83
    Mar 2008
    CSD
    CSD is offline
    Oct 2003
    Centre vents on a vh are fresh air only - NO heat.
    Read your handbook it states it in there as well.
    VH + VK Gas Cars
    May 2004
    Quote Originally Posted by benny999 View Post
    um my vh sl wagon did? explain?
    Could have been some homemade plumbing by a previous owner?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Quote Originally Posted by CSD View Post
    VBs do, VCs do, so VH should do to. But since this is an SL/E, it would have air con. Perhaps the aircon is fluffed.
    Vh sle 5ltr 83
    Mar 2008
    yeah my aircon doesn't work i took off the pump cause it was in the way but it didn't work before that .. wires missing on the pump if i got a new pump hoooked it all up and got the aircon working properly should that fix my drammer?
    CSD
    CSD is offline
    Oct 2003
    believe me unless someone has done some homemade plumbing as stated above you won't get heat through the centre vents.
  1. New heater hoses now no heat?
    By fergies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2008, 03:16 AM
  2. White face gauge problems
    By Snotty in forum General
    Last Post: 11-07-2006, 04:35 PM
  3. Pacemaker Extractors On The V6 What Problems Will I Face
    By JAILBREAKIN_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2006, 09:14 PM
  4. vx berlina heater face/foot problem
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2005, 11:37 AM
  5. Heater that doesnt heat much at all
    By stockVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 08:32 AM
