Is it possible to put a cold air induction on a carby fed 202.. if so how much would it cost and can anyone put up any pics..
thanks dan.
I did a cold air pipe from inside the LH chassic rail/radiator support and cut back the pipe tot he original air cleaner and jammed the cold air pipe over it and sealed it up with gaff tape as an experiment and it made the car run like crap it would overrun decelerating at higher speeds and backfire out the exhaust promptly put it back to stock.
Prob much better off doing an EFI conversion
cheers
Scott
