Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: 308 conversion into vh sl/e
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    Default 308 conversion into vh sl/e
    hey guys
    getting a 308 wagon this weekend so thought id get a head start on some info.
    will the tailshaft and diff fit from the wagon into the vh sedan..
    CSD
    CSD is offline
    Oct 2003
    Diff from the wagon has different shock mounting points to that of the sedan.
    I think with the tailshaft the back section is the same just use your front section. Could be wrong though someone else will correct me if that is the case.
    Dec 2008
    Perth, NOR
    so ill have to just leave the diff the sle has in it and possibly the tailshaft and find a sedan one or am i able to remove the axles centre and pinion and transfer to the sle diff.
    (only worth doing if it ends up been lsd)
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Axles will be to long for the sedan housing. Also, i think the tailshaft in wagons are a tad longer, not to sure on that.
    Dec 2008
    Perth, NOR
    too long really oh... dont think it worth changing the diff anyway as im pritty sure its a 2.6 ratio so ill look for some decent sedan items later on..
    thanks guys
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The wagon and the sedan have the same wheelbase so the tail shafts are the same. The only difference is the transmission type for the front yoke. I thought the diffs were the same apart from the shock mount and the wagon having stabilizer bar mounts. The ratios were different depending on the engine and trans combo except LSD, which were all 3.08:1.
    *edit* After reading the post above you must have the 308 trimatic, that is the one that had the 2.60:1 diff.
    Visit my Facebook page
    Dec 2008
    Perth, NOR
    Dec 2008
    Perth, NOR
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No, well...up to the diff it will but the rear end is different where it has to go around the tank.
    Dec 2008
    Perth, NOR
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes, over the diff and out the back will need a new piece either made or bought.
    Dec 2008
    Perth, NOR
    thanks mate...
    love this forum all the answers ive asked have always been answered the same day
    thanks again fellas
    Dec 2008
    Perth, NOR
    well nealy finished the conversion..
    but the tailshaft are differnt i tried seperating them and cant swap the front shafts over,
    the wagon one is a tad longer but wont fit in the u bolt craddle uni is too big...
    the 6cyl tail shaft fits inside the gearbox but only goes in say 5 cm or less??
    and suggestions??
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Why can't you swap them over? The centre bearings are the same aren't they? The only drama you may have is that it will be unbalanced and may vibrate.
    Just realized the 6 is longer than the 8 so therefore it would have a shorter tailshaft.....
  15. #15
    Dec 2008
    Perth, NOR
    yeh undid the 6 allen key bolts and the rear shaft of the 6 wont fit the 8 front shaft centre brg differnt size, so i tought id undo the circlip and slide the joint off an dfit the 6's joing to the v8 front half and cant do that either as the spline for the joint is differnt size..
    the 6's tail shaft is on the car atm but the front yoke only covers the exposed spling on the gearbox and u can rattle it by hand so it wont be moving with that on there, only thing i can think of is possibly removing the pinion flange from both diffs and swapping them over so i can fit the v8 tail shaft from the wagon
  16. #16
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    can you just change it at the uni joint, not the centre bearing??
    or get a different universal joint to fit the 6 cylinder diff?? on the HQ's (1 tonner) I have got a 6 cylinder tailshaft running into a V8 diff, bought the universal with two end caps one size, and the other two a bit smaller..??
    Just a couple of Ideas,
    I've got a 6 cylinder tailshaft sitting in the garage, but im a bit far away... not sure if it would be any different to what you have already anyway??
    how far are they ment to go in?? cause when your suspension goes down, it will slide in?
    EDIT: I wrote this post a while ago, and just got around to posting it, so most of it is no good. but ehh..
  17. #17
    Dec 2008
    Perth, NOR
    yeh i could change it at the uni if u get it with the v8 size (for the tailshaft) and 2 6cyl size (for the diff)......
    from what i can see the tailshaft should go into the transmission about 15cm atm it is only covering the exposed part of the transmission shaft..
    the front shaft does not move whether car is in the air or on the ground as its bolted solid, the rear shaft moves up down and in out while car is moving
  18. #18
    Zeussy's Avatar
    Dec 2008
    Central Coast
    Ahh kk yeah...
    Its been a while since Ive looked at the old commodore, close to two years, lol, being spending most of my time on the HQ, what you're saying makes sense cause the centre bearing bolts to the floor, no way it can move!!
    Haha,
    Maybe ring a bearing joint tomorrow? see if they have a uni in there to suit, or see if you can buy two uni's and swap the caps over... just measure the 'length' to the uni, cap to cap, and the 'diameter' of the outer cap, and the diameter of the inner 'shaft' they should be able to sort something out..
    thats if you don't already have plans for a V8 diff, or another tailshaft??....
  19. #19
    Dec 2008
    Perth, NOR
    does anyone know if i can use the 10bolt's tailshaft flange on the diff thats in the sle 8 bolt sals.......
  20. #20
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    From memory I'm pretty sure you can get the uni joint with the two different size bearing caps to bolt the diff. I think that is the best and cheapest option. The other way you can go is to try and find a V8 sedan diff.
  21. #21
    Dec 2008
    Perth, NOR
    so i would guess i take both uni joints in to match up too one that has 2 v8 sals and 2 6cyl sals??
    and use the v8 shaft on the 6cyl diff
  22. #22
    Dec 2008
    Perth, NOR
    ok well rang a few places and they arent able to help with the uni.
    but one place said bring down both diff yokes and they will supply me the correct yoke to fit the 6cyl diff running the v8 tailshaft... cost about 50bucks
  23. #23
    Zeussy's Avatar
    Dec 2008
    Central Coast
    ahh no luck with the universal aye?? did they know what you were talking about??
    Yoke looks like it could be the way to go then..
  24. #24
    Dec 2008
    Perth, NOR
    ok can anyone help with the socket size of the pinion flange...i think it maybe a 26 but would like to confirm this..
    thanks
  25. #25
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    If I have read correctly your trying to fit a Borgwarner diff flange onto a salisbury diff or visa versa, give up it wont fit, the pinion gear has different number of splines.
    Instead of stuffing around trying to work out unis why not do what every other person in this situation does and cut off the end of the tail shaft and weld in the correct end. Then use standard Unis
    Have a look on my site for the info on how it is done.
    As for balencing, mark your yoke & tailshaft and press it in to the exact same position and your tailshaft is run true & balenced, I did mine and took it in to be balenced and it was within 1/2 a gram the guy asked me why I brought it in and he couldnt belive I managed to get it spot on, since I have had 3 shafts back to him after building a new tail shaft and each time they run true & balenced
    cheers
    Scott
  1. VS Abs conversion
    By Eldaveo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2008, 10:38 PM
  2. SC V6 Conversion
    By dazza33 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2008, 11:35 PM
  3. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  4. Gas conversion on VP
    By sproaly in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2007, 02:36 AM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
