Results 1 to 11 of 11
Thread: vk fuel injection conversion
    vp
    Feb 2009
    Default vk fuel injection conversion
    has anyone done a conversion from carby to fuel injection using the calais fuel injection system for the 202 and id so what parts do i need eg inlet manifold, computer, wiring, etc?
    and if so what is involved?
    thanks for your help
    vh wagon/efi 202 off road car
    Apr 2008
    Apr 2008
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    or if you want to swap to delco ecu like the vn runs and do away with the stupid flap airflow meter check out sammy's site Sammy's Old Holdens Website & Forums yes it is different than the one above make sure you have the www. or you wont find it.or there are some more details on dizzy mods and delco conversions for the delco ecu on the 202 here Delcohacking.net much better than stock 202 efi ecu
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok
    You need
    Fuel tank & pump EFI VK or VL I would go VL due to the unleaded fillerneck
    Fuel Pump & Brackets
    Fuel pump block off plate that bolts on your engine block where your current fuel pump is now
    Fuel return line & EFI fuel line would be handy as well as its slightly different.
    EFI rubber fuel line (yours needs to be replaced wont handle pressure)
    Electronic Dizzy
    Engine wiring harness
    Fuesbox wiring harness & the special EFI VK relay
    Computer
    Injection manifold
    Injectors
    fuel rail
    fuel pressure regulator
    Throttle body
    EFI VK extractors the original cast iron headers are no good. The stock VK EFI extractors are really good with a couple of mods work exceptionally well.
    Engine sensors there are 3 one on the thermostat housing, 2 on the head. make sure you get the adapter for the coolant temp sensor on the head.
    EFI VK head , you can bolt up onto a carbie head but you will need to block off the EGR ports on the head.
    Cold start valve located down near the dizzy with the air pipe that goes with it. there is also another ported vacumn switch on the bock near the cold start valve.
    Airbox, Air flow meter & intake pipe.
    Cut the airbox mounting brackets from doner car
    Get the mounting brackets for the charcol caniser they are different also and yours needs to be relocated
    Get the alternator/powersteering bracket as yours has an airpump where the EFI doesnt
    I think i have covered parts
    If your using a carbie 202 block you need to drill a small hole for the ported vacumn switch in the block, also fit the fuel pump bnlock off plate while the engine is appart.
    If you need wiring diagrams, hose diagrams I have everything
    cheers
    Scott
    vp
    Feb 2009
    thanks mate, i appreciate it
    i am using a black motor, so is this dizzy right for the job and i have a set of extractors on it already with they fit or will i specifically need the efi headers?
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by rubaduckee View Post
    No, If you have the Carbie Black motor now, it will have EST, which is well pathetic to say the least. Swap it for a Balck EFI dissy, even if you dont go EFI its a big improvement over the EST.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    black or blue dissy will work if your getting one out of a wreck check that the vac advance works by sucking on hose and make sure theres not too much play in the rotor shaft
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by Pub24/7 View Post
    Plus fit a metal gear tot he dizzy, one off an old Oil pump fits and works well
    cheers
    Scott
    VK Executive
    Jul 2008
    Default EST - EFI loom
    I have a loom I modified to fit my EST. Its fairly easy to do. I was going to mount the EFI computer in my original speaker hole with the extra relays mounted beside it. The loom is all pretty self contained I just added my own six pin plug and wired the supply voltages and relays into that.
    VK Turbo build
    My Forum
    Email me
    Anyone can buy one. Its a lot harder to build your own..
    vk executive
    Jan 2010
    i have an efi vk that i had an accident with and bought a new one but its carby so i wanna convert it can anyone help with the steps of what to do? they are both a black motor but new car came with a cam so id rather not strip motor apart n im planning to put a yella terra headd so id rather not pull out motor n just do head and mannifold swap can someone help me??
  1. vh ss 308 (fuel injection)
    By troopymad in forum General Discussion
    Last Post: 18-11-2008, 12:17 PM
  2. fuel injection problem
    By speedee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2008, 04:43 PM
  3. fuel injection question
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-03-2007, 09:16 AM
  4. Injection Conversion
    By jake87 in forum Straight 6 Development And Modification
    Last Post: 01-08-2006, 09:42 PM
  5. fuel injection
    By gungazza in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-06-2006, 02:42 PM
