Results 1 to 7 of 7
Thread: Other manuals that will bolt to a black 308?
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Default Other manuals that will bolt to a black 308?
    I know the aussie 4 speed is a sure hit when doing an auto - manual conversion... but wat other manual transmissions can bolt to the black turbo pattern V8?
    I am getting a new one to replaced my shagged T400 and REALLY want a manual and wouldnt mind a 5 speed. Also this motor was pulling 350hp at the wheels so it has to be aeasonable tough trans.
    Cheers fellas
    Wade
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    T5 out of a EFI V8 will bolt straight up.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    Quote Originally Posted by SL/ENUT View Post
    ofcorse! same block n all.
    Cheers mate!
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Tremec T5 or the Borgwarner T5 5 speed boxes both will the are my prefered box mechanically eash fit.
    No when looking for a gearbox dont forget the same boxes were used in F0rds of the same era just a belhousing swap and your in business.
    Else
    Supra 5 speed
    cheers
    Scott
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Spot on, and an Aussie will not bolt on, it being an aussie/tri pattern IIRC and well the TH box being a turbo pattern.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    In that case, will a T5 bolt onto a Trimatic pattern block? Or do I need an adaptor of sorts?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    You could use an adapter but better off getting a trimatic bellhousing.
  1. Replies: 73
    Last Post: 04-02-2009, 04:54 PM
  2. How Many VN/VP Manuals?
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2007, 09:40 PM
  3. Manuals???
    By BMS-7OY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2006, 01:05 AM
  4. manuals
    By kiwicmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-07-2005, 09:34 PM
