Results 1 to 9 of 9
Thread: vk calais ignition errors!
    benjiaka's Avatar
    benjiaka is offline You Gon Ride or die?
    Vk Calais 1985
    Sep 2007
    Adelaide, Australia
    Default vk calais ignition errors!
    warning light comes up on my vk calais, ' low coolant ' and ' low oil '
    But neither are low?
    :S
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    benjiaka's Avatar
    Vk Calais 1985
    Sep 2007
    Adelaide, Australia
    NORTI's Avatar
    May 2004
    depends, you will prob find that the coolant sensor is corroded pretty badly. Im not even sure they are available new anymore. The oil one may have become heat damaged
    benjiaka's Avatar
    Vk Calais 1985
    Sep 2007
    Adelaide, Australia
    NORTI's Avatar
    May 2004
    the warning beeps will keep going if there is no reading at all from the sensors....
    Ill try & get a pic from NUFNSUS for you as I dont have a VKC anymore
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    This is from someone I know that works in the parts area at our local Holden.
    theres 2 types of coolant level sensors the v8 and 6 use the same one but one of them has a "Pin Terminal" and the other uses a "Blade Terminal", both of which are available for under 85bux each
    VK Calais
    Feb 2006
    Under your dash should be a moulded white/brown coloured circuit board about 30mmx30mm. Removing this from its socket will stop the low coolant warning, and I'd quite confidently say it will also stop the oil one, give it a go.
    benjiaka's Avatar
    Vk Calais 1985
    Sep 2007
    Adelaide, Australia
    so you mean behind my dash?
  1. help! installing vs ignition into a vn calais
    By vncalais01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2007, 05:40 PM
  2. Errors #81 & #83
    By Sylvester65 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2007, 08:14 PM
  3. VK Calais 308 Ignition
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-04-2006, 08:31 PM
  4. Ignition Problems with my VR Calais
    By JoshTaylor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2005, 08:06 PM
