Results 1 to 15 of 15
Thread: Speedo cable?
    VH Commodore
    Mar 2009
    Franga(vic)
    Default Speedo cable?
    where does the speedo cable connect to on the transmission on a v8 please help thanks
    vb sle
    Jan 2009
    adelaide
    VH Commodore
    Mar 2009
    Franga(vic)
    vb sle
    Jan 2009
    adelaide
    VH Commodore
    Mar 2009
    Franga(vic)
    yeah pretty sure its trimatic man thats ok cause im gettin a box strengthened with a stally
    vb sle
    Jan 2009
    adelaide
    na theres nothing rong with the trimatic i think they are a great box unless its standard and youve got 400hp
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    they wernt called a traumatic for nothing weak as .
    VH Commodore
    Mar 2009
    Franga(vic)
    yeh man hows this after getting a new battery new pos and earth cables check the starter 3 to 5 times then changing all fuses and an auto electrician to check over it then i got new spark plug leads it was the sparkplugs letting me down ha ha
    VH Commodore
    Mar 2009
    Franga(vic)
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if you want to drive it hard ide go either turbo 350 or vn T700 but if you have trimatic pattern block you need the 2 lower holes filled and redrilled to suit turbo pattern stupid holden its only out by half a hole on both holes.you can get the bellhousing welded to.
    VH Commodore
    Mar 2009
    Franga(vic)
    в∞ѕтεכ √&
    Jul 2008
    NZ
    speedo drive on drivers or passenger side trimatic will be on passenger side t350 drivers side also trimatic have an id plate close to the gear sellector
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    what about using an adapter plate for t700? Would that make it weak using one of those?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    be all good theres one on ebay right now actually.you need to space the torque converter out from the flexplate too
  15. #15
    vb sle
    Jan 2009
    adelaide
    like i was saying delcowizzid not good for high hose power unless it built right and as for a th700 there not that good eva
  1. Vk Speedo cable
    By Mr Natural in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-01-2007, 12:18 AM
  2. rem cable
    By ben k in forum Car Audio
    Last Post: 20-04-2006, 05:45 PM
  3. handbrake cable
    By robcom in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-01-2006, 10:47 AM
  4. Correct cable?
    By desruction in forum Car Audio
    Last Post: 04-01-2006, 06:09 PM
