Results 1 to 11 of 11
Thread: how to hookem up
    vb sle
    Jan 2009
    adelaide
    Default how to hookem up
    dose anyone know how to hook these up any help would be great.[IMG] [/IMG]
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    lol i have the EXACT same gauges
    ok well first things first, did it come with the after market senders to replace the stock holden ones? and guessing that u have an SL/E its a V8?
    The senders are important cause they screw into the block and manifold where the holden gauges senders were to get a correct reading. I tried to use the holden ones for these gauges and they gave me some wild reading (lol 200celcius at idle? i dont think so).
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    vb sle
    Jan 2009
    adelaide
    na i dont have the senders ill have to get them would you have the diagram as mine are second hand.yea v8
    vb sle
    Jan 2009
    adelaide
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    Alright, now i have lost my little diagrams but i will try n remember. Now are there ANY marks next to the wire contacts to say wat ones are wat? If i remember right, the middle might be the signal wire but its all in the air im affraid. Remove all of those loose wires and it should say something.
    Do u need to also know where on the block the wires go as well or do u have that sorted?
    vb sle
    Jan 2009
    adelaide
    so signal wire goes to senders aka oil pressure switch and temp switch.also where did you hook your positive and negetive to?
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Those red wires go to a power source...ignition source is the best way to go (so the gauges come on with ur igniton). The black is earths, and the greens would be to go to the senders......well thats how it would normally be if ya go by colours....but with the way the lights are hooked up, maybe the greens are earth, and the black is to the senders.....there will be something to describe them there. If ya can't work it out, let me know coz we recently pulled a set of those out of our race car so I'll go have a looksy.
    As for the senders....maybe look in a Speco catalouge, which Repco would have. They are electrical gauges so make sure u get electrical senders. Mechanical oil psi gauges have an oil line running to the back of the gauge, and the mechanical water temp has a copper line going to the back of the gauges. Electrical ones are legal (which is wat u have there) but mechanical ones are illegal, the reason being if the oil line bursts ur gonna get a face full of oil.
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by leigh 7005 View Post
    The negative, just join them both together and chuck a ring terminal on the end and screw it into something metal on the car (or use an existing screw).
    The power wire ya could run from anything which has power (use a test light). Look for a wire which is live with the ignition on, and off when the ignition is off, that's the best way.....well the best way would be to run a new wire from the fuse box, but ya don't have to do that.
    The wires for the lights will be a power and earth. Ya can earth these out on the same earthing point as the gauges....but for power it's best to find a wire which is live when the lights are turned on (and goes dead when ur lights turn off), and tap into that.
    vb sle
    Jan 2009
    adelaide
    yea green is sender its marked i see now where did you put the positive to?
    vb sle
    Jan 2009
    adelaide
    DANNY8's Avatar
    Apr 2004
    ok thanks also did you read my other post cheres
    Which one are u referring to?
