Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: is this longer
    vb sle
    Jan 2009
    adelaide
    Default is this longer
    [IMG][/IMG]
    now my question is on the borg diff from a vk is this bit longer on a vl one? and i know its a salsbury diff its just a refrence. also where my center bearing on tailshaft bolts up it is treded has anyone fixed one of these pricks before?
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I used a VL diff in my old VH, and used the rear half of the VK borgy tailshaft....didn't run into any probs....since then I sold my VL diff and we've got a few VK borgy diffs, which have bolted in the same with the same tailshaft with no probs.....so altho I don't know for sure if they're different, I'm 99.99% sure they are the same....they'd have to be....the only major difference between them is the gears and the VL diff is slightly wider.
    I had a stripped out hole for the centre bearing.....was also in my old VH.....my uncle helped me fix it, I rekon he rethreaded it with a tap and die set. If worst comes to worst, pull up ya carpet and drill out the hole, weld a nut to the floor and put new bolts in underneath.
    vb sle
    Jan 2009
    adelaide
    thanks for that i dont know why its not fitting the ive got the vk tail shaft in and its say about one inch off at the center bearing but if i split it and use salsbury its to long and dosnt fit im stumped
    vb sle
    Jan 2009
    adelaide
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by leigh 7005 View Post
    and the thred is f@#ked i tryed taping today but no luck
    Consider a helicoil in the nut rather than welding in a replacement.
    cheers
    Scott
    DANNY8's Avatar
    Apr 2004
    Can u take some photo's of ur tailshaft and underneath ur car where the tailshaft bolts up? Would love to have a suss coz something doesn't seem right.
    vb sle
    Jan 2009
    adelaide
    ive got some pictures of the tailshafts so you can have a look [IMG] [/IMG]
    vb sle
    Jan 2009
    adelaide
    DANNY8's Avatar
    Apr 2004
    Hmmm.....the only thing I can think of is maybe it's not a VK borgy tailshaft. Where bouts did u get it from? As VL's and VN's and onwards have different transmissions all together, could it be out of one of them?
    vb sle
    Jan 2009
    adelaide
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The top one isn't a 6 cyl one is it?
    Visit my Facebook page
    vb sle
    Jan 2009
    adelaide
    vb sle
    Jan 2009
    adelaide
    vb sle
    Jan 2009
    adelaide
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    What exactly are you trying to do. ie: Car-engine-transmission-diff.
  16. #16
    vb sle
    Jan 2009
    adelaide
  17. #17
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    In what? VB SL/E V8?
  18. #18
    vb sle
    Jan 2009
    adelaide
  19. #19
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You are going to need the front half of the original tail shaft and the rear of a BW tail shaft. Or you can change the rear yoke on your original tail shaft.
  20. #20
    vb sle
    Jan 2009
    adelaide
    nope unis are diffrent and ive tryed front salsbury borg rear still no go
  21. #21
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Are you using a 6 cyl tail shaft as the original unit? Was that one in the picture out of the car? Then that is your problem. You need a V8 shaft as they are longer at the front. That will put the centre bearing in the correct position, then it is a matter of using the rear half of a V8 BW shaft.
  22. #22
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Nice to see people stealing my pics for them selves!.
    Anyway, the area where the centre bearing bolts up, i took mine out cause both threads were rooted and put in bolts in there, so now it has two studs.
  23. #23
    vb sle
    Jan 2009
    adelaide
    was that your picture? i googled salsbury 10 bolt pictures and thats what came up
  24. #24
    the lightning
    Jun 2005
    under the Southern Cross
    a complete V8 VL tailshaft goes straight in, dont have to stuff around with a VB-VK front and VL rear
    Quote Originally Posted by one_and_only2004 View Post
    Sounds like you and your friend have a collective intelligence rivalling that of a door knob. Looks like the useless crap you fit to your car is the driver.
  25. #25
    vb sle
    Jan 2009
    adelaide
    really do you know anyone with one? anyone? i really need to get my beast running again its been 3 years and the toyota creshitta dosnt cut it lol
  1. will longer rods give me comp?
    By 96SEN8R in forum V8 Development and Modification
    Last Post: 03-02-2009, 05:27 PM
  2. No longer in control of my life.
    By Tasmaniak in forum The Pub
    Last Post: 29-06-2006, 09:06 PM
  3. YAY unemployed no longer!
    By gocommygo in forum The Pub
    Last Post: 20-02-2006, 05:33 PM
  4. A/C No Longer Cold VS
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 12:13 PM
