Results 1 to 8 of 8
Thread: installing torque converter HELP URGENT
    Stevo-d is offline Calais Lover
    VK Cusom build (mock Calais)
    Mar 2005
    Default installing torque converter HELP URGENT
    Hi all,
    I'm installing a replacement auto transmission in my VK... am having some real problems aligning the torque converter.
    Under suggestion from a workmate, I have the torque converter removed from the flex-plate/flywheel with the intention of installing the torque converter to the transmission first, then bring the transmission up to the block, bolt it on and then secure the torque converter back to the flex plate.
    problem is installing the torque converter all the way into the transmission.... I have the old trans' and torque converter - can get it onto that one with some difficulty but i cant find a good method of fitting it on easily.
    Will keep trying, but any tips would be greatly appreciated.
    Thanks, Steve.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    just turn the torque converter on the shafts until it clicks all the way in you may need to turn it a few times till all the splines and the 2 tags line up and it slots in
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    We ran into this problem a few years ago. We put a new motor in a VH and just put it together as we pulled it out.....then it wouldn't crank over or nuthin, never even knew there was a special way to put the torque converter in, and yeah as it wasn't in properly nothing would move.
    What we normally do now is stand the trans up on the piece of wood (back of the trans on the bit of wood), then put the torque converter in, and spin it a few times and let gravity drop it in. You'll find when it goes in enough it will be scrubbing on the back of the bellhousing, but when ya put the trans on and bolt up the torque converter through the inspection plate it pulls the converter back a bit and everything is fine!
    vr executive
    Oct 2008
    tassie
    , turn it a few times till it clicks /drops in i think there are two or three stages where it will click in furthur each time
    vb sle
    Jan 2009
    adelaide
    the lightning
    Jun 2005
    under the Southern Cross
    turn converter and let the splines engage, make sure its full of fluid.
    Quote Originally Posted by one_and_only2004 View Post
    Sounds like you and your friend have a collective intelligence rivalling that of a door knob. Looks like the useless crap you fit to your car is the driver.
    Mar 2005
    Thanks guys, did get it on eventually.... I think filling it with fluid did help, and yeah, it was pretty much up against the bell-housing once it was in properly... gave me about 30mm to play with to bring it up to the flywheel/flex-plate.
    Thank you all for your advice, very much appreciated.
    Steve.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    my mate got impatient with his converter and hoped that by tightening the bell housing bolts it would make the problem go away. well, it did kinda. he destroyed the pump in the trans....
    moral of the story "DONT BE IMPATIENT"
    lol. congrats on success, its a bit of a pain sometimes.
  1. torque converter or something else?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2008, 06:56 PM
  2. vr/vs torque converter
    By bigpig in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2008, 11:13 PM
  3. torque converter
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2008, 03:26 PM
  4. Torque converter?
    By spauldj308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-02-2006, 07:02 PM
  5. Torque Converter
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 03:52 AM
