Results 1 to 6 of 6
Thread: Ford T5 behind 202
    jakbob's Avatar
    jakbob is offline Lighten up.
    VX SS, VC L, VK Vacationer
    Dec 2008
    Default Ford T5 behind 202
    Hey there, I've been wanting to put a T5 behind the 202 in my vk. Its currently got a Filipino 4 speed, but I'm building a fairly warm efi 202 so i don't think it'll hold. I've heard the ford t5s are almost identical to a commodore t5 and can be fitted behind a 202. They are available fairly cheaply now.
    CRS has a kit to bolt up a holden t5 to a 202 using a m20 bellhousing (I think).
    My question is, will the CRS kit work for the ford t5?
    I also hear that the ford box has taller ratios. Would this be a problem?
    Thanks.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    The Ford Borgwarner T5 is a great match, the adapter plate using the M2x series bellhousing is fine and works well. make sure you get the speedo drive witht he box as you need to unscrew the electronic part off it and have a speedo cable made to screw onto it.
    I would also get the tailshaft as you may need to do some marrying up of parts there.
    Clutch works well just standard clutch cable from memory.
    Nothing wrong with the ford ratios they will be fine close to your fillo box.
    cheers
    Scott
    jakbob's Avatar
    Dec 2008
    Ok thanks, but what clutch would i actually run? Not the filipino one I wouldn't think?
    vk commodore
    Aug 2008
    just wondering why you wudnt run a holden t5...coz of the price difference??
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by havick vk View Post
    Price and availability. The ford boxes are alot cheaper usually and easier to find.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VH SL/X Wagon
    Feb 2009
    Sorry to hijack your thread, but I was just wondering, what would be needed aside form the T5 itself to do the conversion from a trimatic? Would I be able to buy an M20 conversion kit, and then flog off the M20 and use the Ford T5 instead? This is for a carby 202 blue btw.
  1. Ford ad
    By kowan in forum Jokes/Humour
    Last Post: 21-06-2006, 02:39 AM
  2. v6 in ford
    By 90VN55 in forum General
    Last Post: 15-06-2006, 07:46 PM
  3. Ford Ad.
    By R Photon in forum The Pub
    Last Post: 10-06-2006, 02:15 AM
  4. Ford doing what they do best !!!
    By sixshooter in forum The Pub
    Last Post: 08-06-2006, 03:32 PM
  5. Ford GT-P or VZ R8
    By minux in forum General
    Last Post: 12-12-2005, 08:28 PM
