Just got new carpet and went to take the seats out and found out one of the hex nuts holding the front seats in is badly rounded should i just drill it out
or is there a better way?
I'd grind a slot in it with a dremel and take it out with a large philips head impact driver (chances are it's rounded for a reason), or get someone to weld a nut to the top of it.
Stilsens.....might not be enough room under there tho.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
I had one jam once ended up grabbing it with a pair of vice grips & also multi grips &very painstakenly undoing ittook ages.
Also you could weld a nut (middle of nut) to the top and remove it with a spanner/socket. Lay a fibreglass blankets inside the car to protect interior
cheers
Scott
