hey guys
just wonering if anyone out there has a clue whats going with my heater fan circut, no fuse in the air con slot but fuse in the fan slot the thing doesnt work put a fuse in the a/c slot and it runs when its turned off, the switch doesnt do a thing im actully missing the compresser and the front fan and a/c radiator so does that have something to do with it?
G,day
I am not even from Australia but from Europe (Holland and found this site by surfing on the inet).
I have a car here in Europe that is basicly the same as the VB Commodore (opel Monza) and the aircon system is the same as from the VB,for as far i found out.
One of your A/C relais is ****ed,its a common problem here wenn the engines is put off and the fan motor keeps blowing a bit,its normal wenn the aircon is put on or the engine is running.
But wenn the switch is in the 0 position it not possible for the fan to run if everything is normal.
Here is a pic of the A/C system:
opel, senator, monza, omega
Relais K6 and K7 make the problem.
The are under the bonnet in the middle of the engine bay,very easy to change by the European Monza/Senators.
