+ Reply to Thread
Results 1 to 9 of 9
Thread: Knocking Noise from under the car.
    SoulGrind's Avatar
    SoulGrind is offline §ôµÏG®ïñD SoulGrind has disabled reputation
    VH SLX - VX SII Calais
    Aug 2004
    Default Knocking Noise from under the car.
    Hello all, I've got a strange problem, my gf's VC commodore has a strange knocking noise coming from under the car.
    I've checked to see if theres any movement on the tail shaft and theres none, i've replaced all the rubber mounts for the exhaust. Yet the knocking happens only when there's more then 1 person in the car (more then the driver etc) I know the noise is coming from the tail shaft somewhere, but i can't pin point it.
    Any ideas?
    Cheers.
    "Zooooom"
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic! SL/ENUT Monaro SL/ENUT Monaro
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    centre bearing rubber probably gone.
    ari666's Avatar
    ari666 is offline celebrate disrepair ari666 W427 ari666 W427 ari666 W427 ari666 W427
    1966 impala
    Mar 2009
    is the car lowered? i.e. is the diff hitting the panhard rod when there is an extra persons weight in the car?
    i would be checking your floor pan with a person in the passenger seat, and a person rocking the car.
    the reason i say this is cos' when the panhard hits, it sounds like the tailshaft.
    my 2 cents anyhoo
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is offline Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Most probably the exhaust hitting the panhard rod. When there is weight in the car, the body comes down and the exhaust moves down with it. There isn't a lot of clearance above the panhard rod, so I reckon the exhaust is hitting it.
    http://www.facebook.com/?ref=home#!/...21292461287296
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    duh, lol, yeah i meant to say exhaust. said diff. lol if your diff hits your panhard your in dire sh1t
    VK SL
    Sep 2008
    Cairns
    We had the same issue with the vp, exhaust was knocking against something as it wasnt secured properly. Old parts had disintergrated
    vh2env is offline jesse vh2env Executive
    vh vacationer
    May 2009
    new south wales
    yerr i got a knocking noise from uder my vh too. dus it only happen wen u take off cuz if so its probably the centermount on ya tailshaft. thats wat mine iss.
    SoulGrind's Avatar
    Aug 2004
    Sorry for the late reply, just incase anyone else gets this problem.
    It ended up being the internals of the diff itself. I replaced them and all is good.
    "Zooooom"
    ari666's Avatar
    1966 impala
    Mar 2009
    ouch.
    good thing you nipped that one in the butt. nothin worse than the clung clung clung noise of a shattered diff.
    especially when you are 100kms from home.
+ Reply to Thread
  1. knocking noise
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2008, 08:43 PM
  2. VR Knocking Noise.
    By AussieHolden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2006, 06:27 PM
  3. knocking noise VR
    By reckless in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2006, 05:43 PM
  4. knocking Noise
    By fudlop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2005, 06:02 PM
  5. VP Knocking BAD noise
    By com123 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 08:45 PM
